Concrete Piles For 40 X 60 Steel Building - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-21-2012, 10:32 AM   #1
concrete piles for 40 X 60 steel building
I have a 40 X 60 steel building and I have been getting different foundations ideas , the floor will be heated with in floor heating, should I be putting in piles or will a monolithic thickened edge slab on grade be sufficient, if I go with piles what size of concrete piles and how deep should they be the frost line is approximatly 4-5' ground conditions are good I don,t want to over engineer but at the same time want to be sure I won,t have trouble down the road
If I go with piles at the columns do I make them level with the finished floor grade or have them below grade
Darryl N is offline   Reply With Quote
steel building foundation crazycousin Concrete, Stone & Masonry 4 03-25-2012 01:53 AM
Pole barn vs steel I beam building. Do they compare structurally? viper Building & Construction 0 05-23-2011 07:17 PM
Embedding Steel posts in Concrete square/level d2blake Building & Construction 0 04-20-2011 08:37 PM
Building on piers & pressure treated posts, or just concrete piers? TinaRap Building & Construction 13 05-08-2010 04:00 PM
building with concrete Unlimited121120 Building & Construction 11 07-11-2009 12:05 PM
