Concrete Pier - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-14-2007, 08:37 AM   #1
Rewards Points: 768
concrete pier
When pouring a concrete pier for a deck footing, do I need to place a pad of concrete in the hole before I start to pour my pier? I was just planning on elevating the sonotube a few inches so that when I poured the concrete it would form a base for the pier. Is this okay to do?
cibula11 is offline   Reply With Quote
Old 06-14-2007, 10:46 AM   #2
concretemasonry's Avatar
Rewards Points: 2,578
When using Sonotubes, it is not necessary to place a pad of concrete in the hole.
concretemasonry is online now   Reply With Quote
Old 06-14-2007, 11:13 AM   #3
Rewards Points: 768
Thanks!
Old 06-16-2007, 07:23 AM   #4
Extreme DIY'r Adk's, NY
Rewards Points: 272
actually the advantage of the tube shaped footing is that it resists lift from frost because of not only its depth but it's shape... if you mushroomed a pour out of it you would negate this advantage.
crecore is offline   Reply With Quote
Old 06-16-2007, 09:13 AM   #5
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Huh?
http://www.asdcosupply.com/concrete/...foot-forms.pdf
- Build Well -
Old 06-16-2007, 10:11 AM   #6
The resistance to uplift depends to a large degree on the soil type and is not that great for a such a very short pier.
There is a similar situation (reversed) for piling. The soil surrounding piling can settle. The friction between the piling and the soil pulls down and puts more downward pressuer on the point bearing piling.
For deck piers, just put the bottom below the frost line. If you really have bad, bad, bad soil, you can muhroom out the very bottom to gain to bering area and reduce and settlement. - I think Sonotube makes a special base fitting to give you a pretty formed cone.
Sonotubes are far superior to a hand dug/formed pier because of the smooth surface and predictable amount of concrete required.
Sleeve options for plumbing through concrete? Bruce L Plumbing 6 06-14-2008 10:38 AM
Extending Concrete Patio Slab bobo Building & Construction 6 04-17-2008 01:17 PM
stone veneer formula tom1st Landscaping & Lawn Care 1 07-08-2006 05:48 PM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 11:27 PM
