Old 07-23-2009, 12:45 PM   #1
Default Concrete patio w/o expansion joints
I hired a contractor to install a stamped concrete patio. I came home from work to find they didn't install an expansion joint where the patio meets the house foundation.
How concered should I be? Do I need to insist they rip it out and intall a joint?
TrentJA is offline   Reply With Quote
Old 07-23-2009, 01:06 PM   #2
Concrete & Masonry
Obviously, an expansion joint up to a foundation is ideal, but is far more important in some scenarios than others
Couple of questions: What part of the country are you in/ climate? What did they pour against, concrete or block? foundation insulation? ground break? wood ?
jomama45 is offline   Reply With Quote
Old 07-23-2009, 02:20 PM   #3
concretemasonry's Avatar
Depending on your patio size, you should also have control joints sawed to control the cracks that will eventually appear.
The joint you are concerned about is a separation or control joint since the slab and the home are on different soils. Concrete has little "expansion" and has a long tern shrinkage that should be accounted for.
concretemasonry is offline   Reply With Quote
Old 07-23-2009, 02:23 PM   #4
I'm in Northern California, Sacramento area. 100+ summers, mild winters with highs in 50's and 60's, only occasional bouts of freezing.
One edge of patio is poured along the concrete slab foundation of my home (10' in length). The other side of patio (15') is along existing concrete sidewalk. The other two sides are completely open.
If the worst thing that will happen is the patio may end up with more cracks I'd be disappointed but could live with it. More concerned it might create problems for my concrete slab foundation of the home.
Old 07-24-2009, 03:54 PM   #5
i'd be more concern'd there aren't contraction jnts sawcut or formed in the surface,,, 1 on ea horizontal plane at right angles to each other
itsreallyconc is offline   Reply With Quote
Old 07-24-2009, 04:00 PM   #6
There are contraction joints, one horizontal in the middle on through the vertical middle and it has a band around the edge seperating the stamped area from the smooth concrete area so shouldn't be an issue with that.
I did check with local building code to be sure expansion joints aren't required and they're not so I guess it'll work as-is.
Old 07-24-2009, 04:21 PM   #7
Civil Engineer
See http://www.johnbridge.com/control_joints.htm for an interesting discussion on expansion joints, contraction joints, and construction joints. In your case, it sounds like you have the contraction joints covered, but you really should have an expansion joint between the slab and the foundation of the house. The expansion joint would normally consist of a space at least 1/2 inch wide, filled with a flexible material that was watertight, such as cork, silicone caulk, butyl rubber, or similar material. The purpose of the joint would be to avoid exess buildup of stress in the concrete of either the patio or foundation when the concrete expands during the summer heat.
Note that the johnbridge site claims that concrete will expand 2/3 inch per hundred feet of concrete per hundred degrees F rise. In you case, the temperature difference between summer and winter is some 50 degrees, hence 1/3 inch per 100 feet of patio. Since your patio is about 20 feet, that is about 1/15 inch of movement, so you would not need a large expansion joint, only about 1/8 inch in theory, so you could in principle saw cut it if you could get a blade that close to the foundation. There may be an offset saw that could do it, I have never seen one, but there are lots of unusual tools out there.
Old 07-24-2009, 05:28 PM   #8
danny, that's almost probably more'n even i wanna know good link, tho, & thanks for posting it,,, i'm only aware of a flush diamond blade which's specific to wall saws,,, would almost bet slab shrinkage's compensated for the lack of exp jnt mtl.
i'd bet the 'band' is the trowel track on the perimeter,,, its not common for exp jnt mtl to be removed to accommodate jnt sealant on residential work but, as you're probably aware, the reason for most hgwy slab failure's the lack of properly-spac'd jnts together w/proper sealing to resist the intrusion of 'incompressibles' which cause slab blow-ups.
thanks, AGAIN ! ! !
More On This Topic
Determining where you are going to put a new patio is just the first step in making this addition to your home. After you figure out just where the patio will be, it's time to start prepping for the project. There are a few things to think about during... Read More »
The dry-mortar method is an easy way to fill the space in masonry joints when you're building a patio. One of its advantages is that the mortar keeps those pesky weeds from sprouting. Whether you're using bricks or concrete slabs, consider filling the... Read More »
Creating an inviting outdoor space by building a patio is a great idea, but can become a great headache if not well thought out. Put together a budget and develop your project plans before getting started and your wallet and home will thank you for it. Read More »
If you are planning a concrete project, you will be dedicating your time and money to making it perfect. Whether you will be doing the job on you own or hiring a contractor, there are a few things you should think about before getting started. While it... Read More »
So here we are, on the other side of the room, and it's just getting so exciting. We hope to wrap this up, in the next couple of days. Tomorrow our closet gets installed, we have, my idea, about the door, still to execute with cutting it in half... Read More »
Will pay for patio advice! :) DirkPitt Landscaping & Lawn Care 6 07-31-2009 04:35 PM
Building deck over concrete patio stro77 Building & Construction 8 06-25-2009 06:21 PM
repairing concrete patio flooring & attached walls 1655graff Remodeling 2 01-21-2009 02:21 PM
Concrete Patio drainage problem lakekids Building & Construction 5 07-17-2008 07:27 AM
Concrete Q: expansion and contraction after 30 years Deck Building & Construction 9 05-23-2008 01:21 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
