I will be pouring a concrete patio next week which will be 10x12' and everything I see states the control joint needs to be 8-10' apart. Should I place joint in center from each direction? The patio will only be for foot traffic and no cars will park on it.
Also, I dug out the earth so the patio will be flush with ground when complete and used 1.5" of #57 gravel as base and will pour ~3.5-4" of 3000 psi so is rebar or mesh needed? I have rebar from the last step on concrete stairs so it will hold to new patio but thought gravel base would be OK for this application?
