Concrete Patio - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-07-2011, 11:26 AM   #1
concrete patio
I have a 14 x 14 wood single slope patio cover that I would like replaced with a hip roof. I have an issue with the patio. If you walk out my back door you step onto a 3 x 3 slab connected to the house. Then the remain 11 feet down on each side is pavestones. There is however more concrete slab to the left and right of the pavestones to make the square patio. My question is can I pour a concrete slab on top of the pre-existing slabs if I remove the pavestones to make a solid 14 x 14 slab. I have 5 inches height to the door edge.
kline78 is offline   Reply With Quote
Old 08-07-2011, 01:58 PM   #2
If you have any frost movement the new 'coat' will likely crack along the edges of where the old concrete is.
To work around the old concrete, it will probably cost as much, as if the old concrete is removed and everything totally replaced.
The Following User Says Thank You to Wildie For This Useful Post:
kline78 (08-07-2011)
Old 08-07-2011, 02:08 PM   #3
What if I poured 5 inches of concrete on top , used rebar attached to old slab and adhesive. I have several bids that say this would be more cost effecient than demo and pour new. I want this to last long term.
Old 08-07-2011, 10:36 PM   #4
Then get rid of the old slab then, and pour the whole thing as a unit.
Anything else is speculative.
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 06:25 PM
High Rise Building methods - US versus Oz - Steel versus Concrete Jado Off Topic 17 09-15-2011 08:47 PM
Decided to go with new concrete patio gante Landscaping & Lawn Care 0 03-19-2011 11:11 PM
Stain a large concrete patio (or paint?) ArizonaJay Painting 1 11-14-2010 01:02 PM
Extending a Concrete patio luweee Building & Construction 7 05-29-2010 05:52 PM
