Concrete Pathway Formed - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-21-2010, 06:24 PM   #1
Ada
concrete pathway formed
I am having a concrete pathway formed in between my house and neighbours. My house is lower than the neighbours and I have been told that when the cement is poured the bottom row of my house bricks at the foundation will be partially covered in some areas and totally covered at other areas. Should I insist that the workers dig down further to avoid my house bricks being covered by the cement? Thank you.
Ada is offline   Reply With Quote
Old 06-22-2010, 06:48 AM   #2
Rewards Points: 4,534
slope of the sidewalk will be of more importance due to rainwater standing against the brick & eventually penetrating them,,, asphalt-impregnated ' isolation joint ' mtl should be placed against the brick to prevent this AND also from the new concrete abutting the wall.
Old 06-22-2010, 12:15 PM   #3
Rewards Points: 1,910
You need to make sure the weep holes remain above the concrete and the concrete slopes away from the house.
Old 06-22-2010, 02:58 PM   #4
Handyman
Rewards Points: 512
Location, location, location! oops, wrong thread...
Slope, slope , slope.
Can they embed a secondary rigid weeper directing water away from the house, say, toward the street?
canadaclub is offline   Reply With Quote
Old 06-22-2010, 11:00 PM   #5
Concrete & Masonry
Rewards Points: 530
If the house is older, there are probably no weeps to worry about. If the house is newer, hopefully the masons had enough sense to raise the weeps a few courses. As IRC stated above, make sure they use an expansion material like felt.
jomama45 is offline   Reply With Quote
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 07:25 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
how to fill the gaps between concrete blocks? micapavlov Building & Construction 4 01-03-2010 05:53 PM
Help!: 4" concrete over 2' dirt over 7/8 wood planking! agent99 Flooring 4 04-28-2009 09:21 AM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 02:32 PM
