Old 07-04-2009, 02:58 PM   #1
Concrete Patch
I am working on cleaning up my basement floor. I want to patch some holes. I purachsed hydraulic cement (DRYLOK Fast Lock). The directions mention undercutting, chiseling a "reverse V". Is this necessary for holes I am trying to fill? THanks for taking a look.
joetab24 is offline   Reply With Quote
Old 07-05-2009, 09:24 PM   #2
Remodeling Contractor
Concrete Patch
it would help. you need to chip away any and all loose concrete around these holes first. I would then apply a coat of thermo bond (bonding agent) to help the new stick to the old.
Old 07-05-2009, 09:48 PM   #3
Concrete Patch
thanks for the reply.
never done this before. i am not sure i understand the "reverse V".
Old 07-06-2009, 06:13 AM   #4
Concrete Patch
it is just a way to open the crack more to allow more cement into the area for the patch. The top of the "v" is at the surface and you are angling the 45 degree cuts into the crack to open it up under the surface more. Not an issue with what you are patching.
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 36 08-05-2012 11:43 AM
How to level small patch of cured concrete? RDS General Discussion 11 06-05-2008 01:41 PM
Concrete patch for lally column footing? AllGoNoShow Building & Construction 6 10-21-2006 09:16 PM
