Concrete Pad Flacking , Cracking? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-04-2011, 07:53 PM   #1
I joined to try to get some in site on a problem I am have with a pad that was poured in September of last year. Can one of you guys look at the pics and let me know what happened. Thanks
ANDY93Z is offline   Reply With Quote
Old 09-04-2011, 09:30 PM   #2
Rewards Points: 150
We call those popouts. It's caused by several factors together or individually. Too much water in the mix or possibly the slab was rained on during the finishing stage. It can also be from drying too quick. Around here if the temp at pour is above 90F, the pour does not happen because by the time it's poured and the finishers are able to get on the slab, it far too hot and you'll get these popouts. Most of our slabs here are poured before daylight so this isn't an issue. Our pours usually start at 3 AM and no, you don't want to live in the neighborhood- it gets noisy at 3 AM.
TrapperL is offline   Reply With Quote
Old 09-04-2011, 09:34 PM   #3
This pour was in Knoxville , TN in September of last year. Thanks for the reply. Would not sealing the concrete and using rocksalt during the winter in freezing conditions cause this also? Thanks again.
Old 09-05-2011, 07:42 AM   #4
Rewards Points: 5,336
Using rocksalt would cause the issue. So would over floating the surface.
Ron
B. Franklin 1759
Repairing concrete slab in shower JohnRoss Building & Construction 0 08-08-2011 01:20 PM
House Main Drain Leaking under Concrete Tom738 Plumbing 0 06-01-2010 07:54 AM
Crumbling Front Porch - Part 2 - The Repair jerseyguy1996 General DIY Discussions 9 04-11-2010 06:11 AM
Filling sunken living room w/ concrete Q's phil. Building & Construction 5 07-10-2009 12:03 PM
Concrete slab cracking sluggermike Flooring 12 10-19-2007 02:40 AM
