Concrete Over Foam Board - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-11-2010, 09:40 PM   #16
Concrete & Masonry
Rewards Points: 548
Originally Posted by GBR in WA View Post
I read 25 for both on compressive-------- Dow=50 on flex strength, pink= 75, not the freezer but 250. I was comparing these:
http://insulation.owenscorning.com/W...=id&ItemID=788
http://www.dow.com/PublishedLiteratu...romPage=GetDoc
Be safe, Gary
Yes, those are both 25 psi, which is what is rarely found at the big box stores, although some of them sell 2" in both. The link for the Owens is the 250 which means 25 psi. The Foamular 150 is the far more common foam, which is 15 psi.
jomama45 is offline   Reply With Quote
Old 01-11-2010, 10:03 PM   #17
Registered User
Rewards Points: 5,498
So we are both right! The box stores should carry everything at every store! It's all their fault. lol That's why one foam is pink and the other blue, when one split from the other company, they took the formula with them.
Another good site for the OP, on sand, fines, vapor barriers, and water in the slab: http://www.buildingscience.com/docum...ms?full_view=1
And for the fork-lift driving Contractors: http://www.stellarcontractors.com/as...loose_sand.pdf
Be safe, Gary
Putting rigid foam on concrete walls...how to lay DriCore in this setup? ChaoticBliss Building & Construction 14 09-12-2012 05:02 PM
Best way to affix 2" foam board insulation to foundation wall BigJimmy Building & Construction 12 07-21-2008 11:50 AM
Can foam sealer be used to seal the spaces in concrete block? marksto Building & Construction 6 04-21-2008 07:48 AM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 01:32 PM
