Concrete Over Foam Board - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-11-2010, 06:46 AM   #1
Concrete over foam board
Im talking with different concrete contractors. None of which are real familiar with pouring over foam board. They want to make ramps and wheel barrel it in. Wouldnt it be much easier to have it pumped in ? Wouldnt there be much less chance of damaging the foam board ?
I understand that the pump will cost from 800 to 1000 more but wouldnt it be worth it ?
Mudball is offline   Reply With Quote
Old 01-11-2010, 08:13 AM   #2
Remodeling Contractor
not needed. The foam board (2") will support the weight of the concrete + worker + wheelbarrow. We do this all the time since radiant heat is normally added to high end houses. We do make plywood ramps (cost of about $150) but more to not move the wire mesh.
Old 01-11-2010, 08:20 AM   #3
Concrete & Masonry
Rewards Points: 530
Same here, if 25 psi foam is used, it will support the wheelbarrows without a problem. We do lay strips of plywood down for light foam & radiant tubing though. If your pouring over radiant, you need to take care in dumping the wheelbarrow: the front bar (in front of the tire) shouldn't contact the tubing when dumping.
jomama45 is offline   Reply With Quote
Old 01-11-2010, 08:27 AM   #4
Rewards Points: 582
We put some scaffold boards down over the insulation. The heating pipes are laid on top of the concrete later and then screeded over with 3 inch sand/cement. Have you been snowed off as well Jomama?
stuart45 is offline   Reply With Quote
Old 01-11-2010, 08:34 AM   #5
Concrete & Masonry
Rewards Points: 530
Not exactly Stu. I still have the employees working on an inside job for a few weeks yet. I actually like some downtime in the winter. I think I might even go on a nice cruise on the snowmobile today!
We've had about 30" of snow (with one big melt) this winter already, so conditions are great IF you like snow.
How about your part of England?
Old 01-11-2010, 08:43 AM   #6
Rewards Points: 582
My daughter has just taken this photo of our cottage. Not quite Wisconsin.
Old 01-11-2010, 07:42 PM   #7
Rewards Points: 4,534
yo, head'd to the world of conc end of the month,,, c'mon out & i'll buy you a beer or 7
Old 01-11-2010, 07:56 PM   #8
Concrete & Masonry
Rewards Points: 530
AHHHHHHH, I really contemplated going this year, but I decided against it. I wish I was going now though, I'd gladly drink your beer!
I've been there 3 or 4 times in the last decade, but not since '06. That was the year one of my guy's enetered the "Bricklayer 500" I got got roped into laboring in the competition. That was the point where I relized I was officially "old." I think that's left a bad taste in my mouth, haven't been back to LV since. I'm sure those beer could have probably helped correct that bad taste though!!!!!!
Old 01-11-2010, 08:22 PM   #9
Thanks for all the help. Its good to know that this can be done by laying down running boards also. We are not going as far as radiant floor heat but I certainly hope we done regret investing in the 2" foam board. We are going to have pea gravel for a base then 15 mil plastic and then the foam board so would there be any problems with using the regular blue or pink foam board from the big chain stores for under slab ?
Old 01-11-2010, 08:29 PM   #10
Master General ReEngineer
Bondo's Avatar
Rewards Points: 628
Ayuh,... That foam will work just Fine,...
The stuff has amazing compressive strength when properly lain on flat grades...
Your regret later will probably be Not putting in the pex....
Good Luck...
Old 01-11-2010, 08:43 PM   #11
Agreed. At least loop the PEX.. it's cheap to do it now. The controls and heat source can be added latter when you realize it would be so nice to be comfortable down there.
Old 01-11-2010, 09:20 PM   #12
Thanks again for all the help and suggestions. Originaly we decided to not use any slab insulation at all but wanted to break some of the cool feeling for the love of comfort and heat bills and hope to get some of our money back. We really dont believe we want to take it to that level of living in this zone. http://www.climate-zone.com/climate/...see/nashville/
Old 01-11-2010, 10:00 PM   #13
Registered User
Rewards Points: 5,216
In your city you have 3729 heating days, compared to this chart, you need 24" perimeter slab insulation: http://www.energycodes.gov/support/slab_faq.stm Don't forget the termite shield, if required.
Both foams have the same comp. strength, but the Pink-O.C. is 33% stronger in flexing.
Be safe, Gary
Old 01-11-2010, 10:20 PM   #14
Concrete & Masonry
Rewards Points: 530
Be safe, Gary
Gary, with all due respect, one is rated at 15 psi and the superior is rated at 25psi. To me that's alot of compressive strength variation, especially for 5-10% more cost. There also (may still be) used to be a foam made by Dow named "Freezer Mate" that was rated at 30 psi.
Old 01-11-2010, 10:32 PM   #15
Registered User
I read 25 for both on compressive-------- Dow=50 on flex strength, pink= 75, not the freezer but 250. I was comparing these:
http://insulation.owenscorning.com/W...=id&ItemID=788
http://www.dow.com/PublishedLiteratu...romPage=GetDoc
Be safe, Gary
Putting rigid foam on concrete walls...how to lay DriCore in this setup? ChaoticBliss Building & Construction 14 09-12-2012 06:02 PM
Best way to affix 2" foam board insulation to foundation wall BigJimmy Building & Construction 12 07-21-2008 12:50 PM
Can foam sealer be used to seal the spaces in concrete block? marksto Building & Construction 6 04-21-2008 08:48 AM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 02:32 PM
