Concrete Over Concrete? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-15-2011, 06:47 PM   #1
concrete over concrete?
Hi all,
I've been reading the forum and there is some great stuff on here. I am finally buying my first house and I am sure to be on here with lots of questions.
My first question is about a garage floor. The garage floor has a couple cracks in it and has settled down so half of it slopes down an inch or 2. So it seems more level in the middle of the garage but then the right half of the floor slopes until it reaches the garage door where when the garage door is closed there is a 1.5 - 2 inch gap under the door. Whats the best way to take care of this? Is there a way to bring the floor back up to level or can I concrete over the existing floor, bring it up an inch and level it that way?
Thanks!
thatnewguy is offline   Reply With Quote
Old 02-15-2011, 07:17 PM   #2
It's doable, and cheaper than having mud pumped under the slab. Make sure to use a bonder, and roughen the existing floor(rent a floor sander, and use coarse grit) Bonder is basically white glue that you put on the existing concrete, let it dry, and the wet cement moistens it enough to stick. You'll probably have to sift out the aggregate for the edge taper. Also, be generous with the bonder in the thinner areas. Don't forget to let it cure for a full week before parking on it.
joebanana is offline   Reply With Quote
Old 02-15-2011, 07:23 PM   #3
concretemasonry's Avatar
Rewards Points: 2,608
Any existing cracks are guaranteed to telegraph through the thin topping.
Dick
concretemasonry is online now   Reply With Quote
Old 02-15-2011, 07:50 PM   #4
What would be the right way to do it?
Old 02-16-2011, 04:08 AM   #5
90 lb. jack hammer, dump truck, compactor, fill, building mesh, how ever many yards of ready-mix, screed, float, trowel, sweat, beer, vacation. (day laborer optional, but recommended)
Old 02-16-2011, 10:35 AM   #6
Concrete & Masonry
Rewards Points: 568
I agree that this is the best long term solution. I'd bet you'd be surprised how much of a void is under the slab currently and pouring an additional layer certainly won't be a long term solution.
I would also at least explore the option of mud jacking to get a pro's perspective on it. The estimate(s) should be free and only cost you a little of your own time.
jomama45 is online now   Reply With Quote
Old 02-16-2011, 11:06 AM   #7
Speaking of voids, the guy doing the water proofing on my basement uncovered a big void under the carport slab. Fortunately it had not settled.
They cut 4" holes and pumped concrete. It was fun to watch.
Regarding the original poster's question, my wife and I were looking at a house that had a carport converted to a garage. The slab had a fair amount of slope on it. It appeared to have been poured that way. Anyway, the garage doors were cut to fit the slope. It worked.
pyper is offline   Reply With Quote
Old 02-16-2011, 07:20 PM   #8
Yeah, with that much settling I would want to make sure there isn't a void under it. I know a guy that jacked up a car and had the jack break through the cement because there was a void under it. Not something you want to happen when you are under the car.
elarreau is offline   Reply With Quote
Old 02-16-2011, 08:37 PM   #9
Rewards Points: 4,638
'sound' out your floor using a 16oz framing hammer,,, hollow means void - dead thump means solid base,,, then coredrill a hold & look !
so far, all the previous posts have been correct - you just need to determine which 1 is right for your floor,,, off cruising for a wk, guys enjoy !
Old 02-16-2011, 09:34 PM   #10
Concrete & Masonry
Rewards Points: 568
Aren't you too old for a Disney cruise????????????
Old 02-17-2011, 02:13 AM   #11
Hello,
I have an old nasty looking concrete patio. I want to refinish it. The plan is I was going to put some 2x4's around it, pour 2 inches of concrete on top, than I have a stamping tool to give it a rock look and I was going to press that in around the patio than let it dry.
Will this work? Other than cleaning the old concrete what prep should I do?
Does it need to be reenforced? I dont see how I would with the stamping tool.
____________
curtains
Marianne55 is offline   Reply With Quote
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 06:25 PM
Tips For Pouring Concrete? Root issues? Thoughts? kronic24601 Building & Construction 5 02-14-2011 06:52 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
Help!: 4" concrete over 2' dirt over 7/8 wood planking! agent99 Flooring 4 04-28-2009 08:21 AM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 01:32 PM
