Old 02-28-2009, 05:58 PM   #1
Concrete/Mortar issues First time home owner Pictures Included
Hello:
I live in the Midwest (chicago) and recently purchased a 100 year old house with a slab foundation. We have had snow melt throught out the winter, about a month ago we had an unusual warm up and a fast melt. We did not get any water in the basement; however recently there was a heavy rain and we got about 2 gallons of water from the cove (floor/wall). I discovered a hole in the cove which lead to me chiseling out old weak caulk. I replaced it with Drylok fast plug. I understand that moisture should be tackled from the outside in so I included these pictures for advice.
Sidewalk is cracked and possibly directs rain water towards the foundation..how to correct this?
Mortar seems to be along the ground and then stops (where I put the yellow circle) I know that the joint needs tuck pointing as well. Since the mortar is painted, does this pose a problem for adding more?
Sidewalk runs right next to the side of the house and there is a gap between...
The soil absolutely needs to be graded to move away from the house..the lowest point of the soil is actually next to the house. How high should I make the soil against the house? Is it possible for me to do this in winter? Or do I need to wait till spring? recomendations for best type of soil?
stefonroman is offline   Reply With Quote
Old 03-01-2009, 08:00 AM   #2
I would clean out the cracks and install a urethane caulk. That will allow movement between the surfaces but maintain a waterproof bond. Attepmting to seal that with a rigid material like cement will never work. Those surfaces move in different ways at different times.
Old 03-01-2009, 08:12 AM   #3
Handy
I'm looking into this myself and have found that it isn't simply adding soil next to the house... recommendations are to dig a trench down, layer with rock, sand, then soil.
Hemingway is offline   Reply With Quote
First Time Home Buyer Woes Jdelles General Discussion 9 10-12-2010 08:43 PM
Pay GC to construct home and finish it myself? L O N G . . . Badfish740 Off Topic 9 07-27-2007 09:44 AM
New 1st Time Home Buyers bhpizza Introductions 14 07-03-2007 04:12 AM
First Time Home Buyer in Need of roofing thoughts 1stTimer Roofing 1 06-22-2007 09:49 PM
new home owner awider Introductions 7 09-23-2006 07:38 PM
