Old 08-26-2009, 10:27 AM   #1
concrete mixes
Hi there.
Part of my wall in the back garden has fallen down. The foundation seems to be ok so i just need to rebuild whats fallen down. Can sumone tell me whats a good concrete mix. silly question, but im not good at this sorta thing. cement, sand, water? should i be adding a coarse aggregate, like ballast? Also what are the ratios? 1 shovel cement.. how many sand? etc
christian2 is offline   Reply With Quote
Old 08-26-2009, 11:05 AM   #2
Moderator
Termite's Avatar
concrete mixes
Mixing the raw materials yourself is pretty risky because getting the perfect ratio of materials is going to be pretty hard to do, and that can affect the finished product quite a bit.
If this isn't a huge project, your best bet is to buy concrete mix in bags. Good old QuickCrete gravel mix is the best choice for this. It has the portland, sand and gravel already in there. Your other option is site-mixed or ready-mix trucks...Site mix trucks are pretty handy for small loads of a yard or two, and are fairly economical. You'll usually spend about the same on bagged mix that you will on truck mix if you get to yard+ quantities, and the truck mix is easier and more controlled because it takes a heck of a long time to hand mix over 30 bags to equal a yard.
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 36 08-05-2012 11:43 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
Help!: 4" concrete over 2' dirt over 7/8 wood planking! agent99 Flooring 4 04-28-2009 09:21 AM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 02:32 PM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 11:27 PM
