Concrete Joint Leaking - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-23-2008, 02:59 PM   #1
concrete joint leaking
i have a situation where a poured wall and a poured ceiling (patio deck)meet (in two different pours) there was never any kind of "keyway" or rubber control joint installed in the first pour to make a water tight joint with the second..now i have some water getting between the pours and leaking into a cold storage room..my question.....is there any kind of liquid sealer that i can "paint" onto the top of the joint to stop the water from getting in now?..i was hoping there may be a clear compound of some kind as this joint is on a patio deck where it is highly visable
just a note..there was a ledge left for the deck (ceiling) to rest on before pouring and when i asked about a water joint of some kind i was assured it was not needed...this is what i get for listening i guess, any help will be greatly appreciated
billie_t is offline   Reply With Quote
Old 07-24-2008, 06:11 AM   #2
you may be able to use zypex or another crystalling penetrating sealant but i think this is beyond the ability of any silicone siloxane to resolve,,, thoro does make a coating that might work - either bagg'd powder or pre-mix'd,,, i'd expect the best method's to form a sealant reservoir & caulk w/100% silicone, polysulfide, or polyurethane.
there're some other methods but either of these'll give you the best bang for the buck.
yesitsconcrete is offline   Reply With Quote
Old 07-24-2008, 06:50 AM   #3
Whatamess
Have you called the people back that did the job and see what they are not willing to fix? File a complaint with the BBB
I may go home hungry, but not tired and hungry.
TazinCR is offline   Reply With Quote
Old 07-24-2008, 08:10 PM   #4
i have contacted my general and he says he can use something to seal it but i came here as i find the longer the job goes on the less i believe in his judgement and i am trying this forum for informationn so i might be able keep him "honest"
thanks for the input from you both
leaking vent stack joint xrayman Plumbing 10 03-04-2008 03:23 PM
Leaking around joint of PVC pipes in attic themadcatter HVAC 10 12-18-2007 09:29 AM
leaking concrete wellcover/manhole johnny331 Building & Construction 1 06-20-2007 04:32 PM
Leaking Basement - Concrete jeepwillies Building & Construction 2 03-06-2007 07:42 AM
PVC drain pipe leaking at joint, 2 part epoxy last? harleysilo Plumbing 3 09-26-2006 12:29 PM
