-   -   concrete joint leaking (http://www.diychatroom.com/f19/concrete-joint-leaking-24154/)
billie_t 07-23-2008 03:59 PM
i have a situation where a poured wall and a poured ceiling (patio deck)meet (in two different pours) there was never any kind of "keyway" or rubber control joint installed in the first pour to make a water tight joint with the second..now i have some water getting between the pours and leaking into a cold storage room..my question.....is there any kind of liquid sealer that i can "paint" onto the top of the joint to stop the water from getting in now?..i was hoping there may be a clear compound of some kind as this joint is on a patio deck where it is highly visable
just a note..there was a ledge left for the deck (ceiling) to rest on before pouring and when i asked about a water joint of some kind i was assured it was not needed...this is what i get for listening i guess, any help will be greatly appreciated
yesitsconcrete 07-24-2008 07:11 AM
you may be able to use zypex or another crystalling penetrating sealant but i think this is beyond the ability of any silicone siloxane to resolve,,, thoro does make a coating that might work - either bagg'd powder or pre-mix'd,,, i'd expect the best method's to form a sealant reservoir & caulk w/100% silicone, polysulfide, or polyurethane.
there're some other methods but either of these'll give you the best bang for the buck.
TazinCR 07-24-2008 07:50 AM
Have you called the people back that did the job and see what they are not willing to fix? File a complaint with the BBB
billie_t 07-24-2008 09:10 PM
i have contacted my general and he says he can use something to seal it but i came here as i find the longer the job goes on the less i believe in his judgement and i am trying this forum for informationn so i might be able keep him "honest"
thanks for the input from you both
