Concrete Garage Floor - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-27-2010, 11:29 PM   #1
Rewards Points: 81
Am replacing a drain pipe under a concrete garage floor. Jackahmmering a trench to accomodate a 4" wide pipe. Backfilling and tamping down prior to pouring the concrete patch. With a jagged cut from the jackhammer, will the patch be suffice with wire mesh only? The trench is no wider than 10 inches or so.
cougar01 is offline   Reply With Quote
Old 05-28-2010, 06:19 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 602
Yes...
Old 05-28-2010, 07:12 AM   #3
Rewards Points: 4,534
you won't need mesh however IF you use it, be certain its centered vertically midpoint +/- 5% which's .2" - i wouldn't use it & don't in 4" slabs,,, its usually not recommended on 4" slabs.
you probably WILL have to score jnts every 15" across the patch OR await while the conc to cracks on its own,,, you probably know to wet the sides of the existing conc so its dryness won't suck out the new conc's moisture
Old 05-28-2010, 07:49 AM   #4
Rewards Points: 81
Thanks for the replies! I guess my main concern was if it would crack over time with the car running over it (pulling in and out of garage)
Old 05-28-2010, 09:13 AM   #5
YES, IT will CRACK,,, since conc likes to be square, we place contraction jnts in it so it'll crk where WE want it to crk.
imagine your patch's a conc highway,,, those joints're placed at EXACT locations for a reason,,, that was our work for yrs - putting specific ' thump-thump ' in conc hgwys to prevent random cracking
Building a shower pan on a pre-sloped concrete floor tsg234 Kitchen & Bath Remodeling 1 02-06-2010 12:29 AM
Options for Cold Basement Concrete Floor? jefferis Flooring 16 12-09-2009 01:23 PM
Annie5 - framing over uneven concrete floor Annie5 Carpentry 9 11-22-2009 04:26 PM
Carpet in the basement Packer Backer Flooring 16 11-04-2008 12:19 AM
Garage concrete and driveway asphalt repairs creamaster Building & Construction 4 07-12-2008 11:51 PM
