Old 10-07-2011, 09:02 AM   #1
Concrete forms
We have built a concrete base around a 4 by 4 holding up driveway roof. It measures 25 by 27 and the height is 18 inches. It has 400 pounds of concrete mixture in it. The forms are of thick plywood.
When can we remove them.
tickifrog46 is offline   Reply With Quote
Old 10-07-2011, 10:29 AM   #2
Tileguy
Bud Cline's Avatar
Concrete forms
When did you cast them?
Old 10-07-2011, 11:10 AM   #3
Msradell's Avatar
Concrete forms
You can easily remove them about 12 hours after pouring the concrete. The concrete will still be "green" or make it easier to remove the forms. Hopefully you didn't embed the 4x4 into the concrete, if you did it will lead to the early failure of it because water will not be able to evaporate from within the wood.
Msradell is offline   Reply With Quote
High Rise Building methods - US versus Oz - Steel versus Concrete Jado Off Topic 17 09-15-2011 09:47 PM
Repairing concrete slab in shower JohnRoss Building & Construction 0 08-08-2011 02:20 PM
furring strips or 2x4s against concrete basement wall? denemante Building & Construction 15 01-28-2011 04:49 PM
Should concrete driveway slab be thinner on the edge by the forms? Studly Building & Construction 6 09-14-2009 10:24 AM
Filling in large openings in concrete foundation shtoink Building & Construction 10 12-04-2008 05:03 PM
