Old 05-17-2011, 05:28 AM   #1
concrete form releasing agent spilled on footings
I have noticed that there is a pool of releasing agent sitting on the concrete footing all along the length of the proposed retaining wall . Some bright light coated the inside of the plywood forms in place resulting in excessive amount of oil on the concrete footing.
Will this cause the wall concrete to not bond to the footing once the form is poured?
Should this oil be removed and the footing degreased?
Thanks for your suggestions
roderickus is offline   Reply With Quote
High Rise Building methods - US versus Oz - Steel versus Concrete Jado Off Topic 17 09-15-2011 09:47 PM
furring strips or 2x4s against concrete basement wall? denemante Building & Construction 15 01-28-2011 04:49 PM
Concrete Form for Raised Patio PerpetuallyRepairing Building & Construction 6 04-08-2008 07:33 PM
Concrete Form Gap Question bjones Building & Construction 1 03-10-2008 07:32 PM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 11:27 PM
