Concrete Form Release - Building & Construction - Page 6 - DIY Chatroom Home Improvement Forum
Old 07-20-2011, 11:28 PM   #76
Originally Posted by concretemasonry View Post
Jeremy -
Here in MN a contractor will remove the forms as soon as possible due to current tempeatures ( 03 10 days ago and a week or so of 90 to 100F with high humidity) to avoid overheating and be able to provide moisture and cooling as necessary. When the aggregate finall warms up that compounds the problem. Some even order concrete with ice or iced water to prevent curing to fast. I think they are still pumping brine through the embedded pipes for control of the concrete curing after many years of placement.
It is good to see you have luxury of using you project as an unmonitored experiment and learning experience.
By the way, I have been a concrete inspector and bridge inspection before getting my Bachelor's and Masters degrees, 40 years experience and 3 international Honorary Doctor's degrees (for whatever they are worth) that just look good on the wall.
Just keep poking around, put things in perspective, learn and share your results.
Dick
It's great that someone with your knowledge and experience is willing to post to a group like this. Your perspective is extremely valuable, especially for someone like me who is trying to do something well outside my area of expertise.
It'll probably be a week or two before I get a chance to do any more work on the "great wall", but when I do I'll post again, including some pictures.
Btw, I spent most of my first 20 years in Iowa, so I know all about those 100 degree (plus) temps with 90% (plus) humidity. I vividly remember high school football practice on one of those kind of days, when the guy next to me had a heat stroke.
Fortunately, we don't get that kind of weather around here---it rarely gets above 80 degrees and when it does, I'll drive 15 miles to the beach and go fish in the surf until the sun goes down.
Jeremy Hillary Boob, PhD is offline   Reply With Quote
Old 07-29-2011, 12:10 AM   #77
The continuing story...
Three days after pouring (i.e., last Thursday), I had some time and some extra help, so I decided to take advantage of the situation, and I started pulling the forms. The forms didn't stick at all, but it still took a while, due mostly to my inexperience. Then my brother was here for several days, so I'm just now getting back to it.
I've patched the snap tie holes and smeared Thoroseal on the backside. All that's left is drainage (perforated pipe, gravel, cloth) and filling in the dirt.
In the attached picture, you can see the wavy top. That won't be too noticeable, since we plan to have ivy growing over the top. I also posted a couple of close-up pictures, one of which is about the worst spots wrt pin holes, and the other is fairly typical.
Overall, I think it turned out pretty OK.
concrete form release-p7280006.jpg   concrete form release-p7280009.jpg   concrete form release-p7280010.jpg
Old 07-29-2011, 10:44 AM   #78
Concrete & Masonry
Rewards Points: 470
Looks good to me, nice job..........
jomama45 is online now   Reply With Quote
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 07:25 PM
New Concrete Walkway along side of house braverichard Building & Construction 0 11-03-2010 12:12 PM
Crumbling Front Porch - Part 2 - The Repair jerseyguy1996 General DIY Discussions 9 04-11-2010 07:11 AM
Extending Concrete Patio Slab bobo Building & Construction 6 04-17-2008 01:17 PM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 11:27 PM
