Concrete Footings For Retaining Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-07-2010, 10:37 AM   #1
concrete footings for retaining wall
We're building a poured retaining wall (about 4' high) and we're just about ready to pour the footings. There will be plenty of rebar but I'm wondering if it is worth adding fiberglass (or anything else) the concrete. The additional cost for the fiberglass is low, so if it adds any strength, I'd definitely use it. Thanks.
Jeremy Hillary Boob, PhD is offline   Reply With Quote
Old 02-07-2010, 10:41 AM   #2
just rebar and a keyway in footing would help. make sure your footing is large enough to handle the lateral push of the fill
The older I get the better I was
Old 02-07-2010, 10:47 AM   #3
Concrete & Masonry
Rewards Points: 620
IMO, no, the fiber will have no beneficial effect in this situation.
jomama45 is offline   Reply With Quote
Old 02-07-2010, 12:27 PM   #4
Rewards Points: 4,750
we use perf'd ADS pvc which comes in 100' coils &, rarely, perf'd s&d pvc - apron store or plumbing supply,,, jo's right but, in truth, fiber's got little beneficial effect to those who know how to place, finish, & joint conc properly - imn-s-hfo, that is
Old 02-07-2010, 12:47 PM   #5
jlhaslip's Avatar
Rewards Points: 2,820
fibre is used on slabs. footings don't benefit from fibre.
Lots of rebar is good.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is online now   Reply With Quote
Old 02-07-2010, 03:05 PM   #6
my post stands - don't see any need for fiber even on flatwork,,, on vert dec sculptured, yes,,, #5 bar is code - 4 runs - 6's better of # 6
Old 02-07-2010, 05:10 PM   #7
Thanks for all of the responses. So, no fiber. Btw, what is a "keyway"? Thanks.
Old 02-07-2010, 05:23 PM   #8
concretemasonry's Avatar
Rewards Points: 2,626
A rigid concrete retaining wall should be detailed, especially the footing size. A simple strip footing is no where near adequate. Drainage and backfill behind the and drains are necessary.
If it is only 4' you can build a segmental retaining wall with no footings permitted since footings are detrimental to this type of wall. You usually need no engineering, unless you are a strange location. With engineering, they can be built 40' high. The big question is whether you wand a smooth face or a colored stone-like face.
Dick
concretemasonry is online now   Reply With Quote
Old 02-09-2010, 04:28 PM   #9
a keyway is just a depression in the footing about 3-4"wide and 2-3" deep. usually in the center of were the wall will be. it works inunison with the rebar that will protrude from the footing. it really keeps the bottom of the wall from kicking. just make one from a 2x4. put a handle on the top and 45 the bottom sides to create a channel.
logan1881 is offline   Reply With Quote
Old 02-09-2010, 05:00 PM   #10
Here's a visual:
http://www.sweethaven02.com/BldgCons...02/fig0638.jpg
HooKooDooKu is offline   Reply With Quote
Shower pan/tile against concrete wall mgray87 Tiling, ceramics, marble 10 09-11-2009 11:50 AM
How to seal a shower pan liner against a concrete foundation wall? mgray87 Kitchen & Bath Remodeling 3 08-13-2009 11:08 AM
Brick wall - concrete slab floor separation. DewmanTN General DIY Discussions 5 07-24-2009 09:57 PM
painted concrete under the wall paper? guygood Painting 3 11-30-2007 11:57 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
