-   -   concrete footing (http://www.diychatroom.com/f19/concrete-footing-68010/)
baas1219 03-31-2010 11:48 AM
concrete footing
I want to pour a footing for a concrete wall. 2' wide,1'thick. Can I use concrete blocks and fill them with concrete? Three across.
fixlife 03-31-2010 12:36 PM
Not really
If the footing is for a giant dog house or small shed, sure. I am sure local code will not allow it. It might be helpful to know what you are using it for.
Concrete blocks are typically used in a vertical setting on a poured concrete footing for foundation where local code allows it.
walkman 03-31-2010 05:01 PM
And pass an inspection? No. You need solid concrete with rebar. Make a keyway in the footer for the wall.
