Concrete Floor Sealer - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-21-2009, 05:57 PM   #1
Concrete floor sealer
Three weeks ago I had a new concrete floor poured in my garage and would like to seal it before the cold weather sets in and subjects it to snow ice and road salt, etc.. I live north of Boston.
How long do I need to wait before sealing the floor. I know it should cure in 28 days or so but it has already been cold here. Any product recommendations would be helpful.
teach76 is offline   Reply With Quote
Old 10-22-2009, 06:56 AM   #2
Rewards Points: 4,454
sher-wms has solvent & wtr bas'd sealers,,, pick whichever you like,,, tree-huggers/pseudo-enviromentalists seem to like wtr-based & re-sealing every yr,,, guys who like to do it only ever 4 or 5 yrs use solvent-based,,, yes, i know, apron stores ALSO sell sealer stuff but you get better results w/sher-wms,,, we use mtls not avail to you UNLESS your local elitecrete distributor'll sell you ' css '
Old 10-22-2009, 07:52 AM   #3
Too Short? Cut it Again!
I've used these and like them. Your temp situation may force you to wait until spring for just about anything if your temps are dropping below the minimum temps stated by the manufacturer of whatever you use. I like these products, by the way although they may be overkill for your application?
http://uscoatingsolutions.com/concrete-paint.html
Old 10-22-2009, 08:10 AM   #4
Concrete & Masonry
Rewards Points: 470
I'm with IRC on this, go to Shewin-Williams to check out the H&C solvent based if you have enough ventilation. Don't forget to look into "Shark Grip" of whatever slip additive they have. IMO, a hard troweled & sealed floor is going to be borderline dangerous in winter W/O an anti-slip additive. The anti-slip works far better in the solvent based sealers than in the water based.
3-4 weeks should be sufficient for any solvent based, even shorter for water based.
jomama45 is offline   Reply With Quote
Old 05-20-2011, 01:32 PM   #5
concrete sealer
what is the differents between solvent and water base sealer. Do you apply these 2 sealers differently or what.
47junior is offline   Reply With Quote
Old 05-20-2011, 01:44 PM   #6
mainly sealability & longevity - solvent based sealers need resealing less often & are more resistant to stains,,, we'll either spray or roll on w/18" rollers,,, ALWAYS keep a wet edge no matter how you apply it
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 07:25 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
Concrete Contractor and Masonry Contractor made a huge mistake homeowner12 Building & Construction 19 07-07-2010 10:37 PM
Help!: 4" concrete over 2' dirt over 7/8 wood planking! agent99 Flooring 4 04-28-2009 09:21 AM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 02:32 PM
