Concrete Firebox Questions - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-18-2011, 05:12 AM   #1
concrete firebox questions
how do i render the inside of a fire place for a wood burning stove on to brick, should i use washed sharp sand, also one or two coats and would i need lime in the mix, if two coats how long in between coats, and should i pva first.
thanks for your replys, gordon
gordon colyer is offline   Reply With Quote
Old 08-20-2011, 02:48 PM   #2
Registered User
Rewards Points: 4,914
Welcome to the forum!
I changed your title and am moving you to another area for faster response.
Gary
concrete porch slab questions Queso Bandit Building & Construction 2 06-29-2011 11:31 AM
Creating a flat floor on an angled concrete floor? Magno Building & Construction 1 04-14-2011 06:42 AM
Questions about concrete stamping prep for patio rovibe Landscaping & Lawn Care 0 07-11-2010 08:56 PM
Help!: 4" concrete over 2' dirt over 7/8 wood planking! agent99 Flooring 4 04-28-2009 09:21 AM
Concrete questions Focus2005 Building & Construction 1 05-31-2005 06:05 PM
