Concrete Fill - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-27-2011, 12:02 PM   #1
concrete fill
I have a gap between my concrete garage floor where it meets the driveway pad anywhere between 1/4 t0 1/2". What is the best material with which to fill this?
pricml is offline   Reply With Quote
Old 08-27-2011, 04:09 PM   #2
Rewards Points: 5,336
A self leveling filler. Google Sika.
Ron
B. Franklin 1759
Old 08-31-2011, 05:14 PM   #3
amuffly's Avatar
You will want to buy some backer rod also to place in the gap then pour self leveler over that.
amuffly is offline   Reply With Quote
Old 08-31-2011, 05:44 PM   #4
Use backer rod and silicon caulk to fill it. Anything that hardens will crack in short order!
The Following User Says Thank You to Wildie For This Useful Post:
concretemasonry (08-31-2011)
Repairing concrete slab in shower JohnRoss Building & Construction 0 08-08-2011 02:20 PM
furring strips or 2x4s against concrete basement wall? denemante Building & Construction 15 01-28-2011 04:49 PM
Laminate Flooring on Two Different Concrete Heights mrken Flooring 4 12-14-2010 02:56 PM
Picking a foundation for shed/simple workshop Corey in NE Building & Construction 30 02-08-2010 12:34 PM
how to fill the gaps between concrete blocks? micapavlov Building & Construction 4 01-03-2010 05:53 PM
