Old 06-17-2010, 04:54 PM   #1
Concrete for fence gate cane bolts?
I have 2 large privacy fence gates that have cane bolts at the bottom of each gate to go into the ground. I have to rebuild it because the way I built it last time didn't hold correctly.
What I did was pour a small square of quikrete below the cane bolts and slid 2 pieces of metal piping into the concrete. I let it dry over night and then slid the cane bolts down into the metal pipes to hold.
The problem came next summer when I went to pull one of the cane bolts out and it pulled the pipe out with it. I now have to rebuild this so is there a better way to do this? Thank you.
Jesse
jpearson311 is offline   Reply With Quote
Old 06-17-2010, 05:30 PM   #2
Use longer pipes and bend the bottom 4 inches, so they can't pull straight out because the bent bottoms hold them in place
ttech is offline   Reply With Quote
Old 06-17-2010, 08:37 PM   #3
we call 'em' j bolts ' down here,,, you could use threaded rod & bend 'em yourself ! never did hear of ' cane bolts ' !
taxpayers voting for obama are as idiotic as chickens who voted for Col. Sanders !
if you hear it from a guy in the apron store, be VERY suspicious the mtl/method will work,,, when it time to build something together, they won't answer phones NOR help
itsreallyconc is offline   Reply With Quote
Old 06-17-2010, 10:13 PM   #4
Thanks a lot guys. The pipe I used last time was too thick to bend by hand, but since it's going into concrete, I suppose I could use a thinner pipe and bend it at the bottom? Oh, and they're called cane bolts because they look like a walking cane.
http://www.lowes.com/pd_106029-1277-CD1009_0_?productId=1118069&Ntt=cane%20bolt&Ntk=i_ products&pl=1&currentURL=/pl__0__s?newSearch=true$Ntt=cane%20bolt$y=0$x=0
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 36 08-05-2012 11:43 AM
What kind of concrete for fence gate bolt? jpearson311 General Discussion 3 04-05-2010 12:31 PM
L bolts in concrete slab... Jeremy Hillary Boob, PhD Building & Construction 4 12-02-2009 11:33 PM
Help!: 4" concrete over 2' dirt over 7/8 wood planking! agent99 Flooring 4 04-28-2009 09:21 AM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 11:27 PM
