Concrete Exterior Foundation Sealant - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-20-2010, 12:37 PM   #1
Does anyone know a product that is used to seal foundation walls thats gray (matches the concrete), and appears to be applied very thin? Was planning to seal my concrete but was told it had already been done, just hard to see.
When I spray the area with water were I was told it was applied/protected the water soaks right in. Was expecting water to bead up and run down the wall.
I'm used to thick black runny tar looking material, not something that looks like model paint. Even something thick gray runny tar stuff - that actually fills the small voids/air pockets.
Just don't want to do the work if the product that's may have been installed will protect the call from moisture.
Thanks!
EWen is offline   Reply With Quote
Old 07-20-2010, 07:27 PM   #2
Rewards Points: 1,910
Above or below grade?
Old 07-20-2010, 11:53 PM   #3
Below grade. Footing/wall up to ground level.
Thanks, D
Old 07-21-2010, 07:54 AM   #4
Rewards Points: 4,656
the usual's asphalt emulsion per bldg code .003" min thickness,,, keyword MINIMUM ! doesn't last imn-s-hfo but it does meet code,,, look on tremco or google delta-drain for the best solutions imn-s-hfo !
sounds as if they used a wtr-based mtl - not acceptable to me NUT ck the specs for the job - it may have been specified !
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 06:25 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
how to fill the gaps between concrete blocks? micapavlov Building & Construction 4 01-03-2010 04:53 PM
Help!: 4" concrete over 2' dirt over 7/8 wood planking! agent99 Flooring 4 04-28-2009 08:21 AM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 01:32 PM
