Concrete Expansion Joint Sealer - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-28-2008, 09:20 PM   #1
Question
concrete expansion joint sealer
My old school fiber concrete expansion joints have dried up and withered away and I want to fill it with that flexible caulking. I have already bought the foam backer rod and stuffed it into the crack after removing the debris but I'm having trouble locating the stuff. It really gets me too because I was just at Target and seen it used just outside their door.
Any of you folks know what I'm looking for?
This site is very cool, many smart people
Stavop is offline   Reply With Quote
Old 06-28-2008, 09:30 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
You are looking for either a Sika Flex caulk or a BASF NP1 style caulk. They are Polyurethane caulking. Try a motar/brick/stone supply house.
- Build Well -
Old 06-28-2008, 09:41 PM   #3
Thank you. This site has been one of the best discoveries I've had.
Old 06-29-2008, 07:01 AM   #4
we like polysulfide as its gas/diesel resistant,,, 100% silicone works well, too,,, have done miles of highways w/it.
yesitsconcrete is offline   Reply With Quote
Old 07-20-2010, 07:23 PM   #5
I've found that Dow Corning has a good pavement sealant for expansion joints. It's good for handling weather extremes and I found it really easy to install. http://www.dowcorning.com/content/co...tion/conspave/
handyz is offline   Reply With Quote
Old 07-21-2010, 09:09 AM   #6
Rewards Points: 4,534
dow's product's good however won't resist gas/petroleum,,, normally its only used on runways & highways.
stadry is online now   Reply With Quote
Old 07-27-2010, 03:13 PM   #7
There's a new method available that will be a whole lot less work than the polyU caulk. Works for residential-type applications with rounded edge slabs and 3/4" joints.
www.trim-a-slab.com
these guys are new, and you can't get it too easily just yet, but it looks sweet.
R&D guy is offline   Reply With Quote
Concrete Q: expansion and contraction after 30 years Deck Building & Construction 9 05-23-2008 12:21 PM
Which Concrete Floor sealer? ombligo Flooring 3 07-07-2006 02:08 PM
expansion joint farrington135 Building & Construction 1 01-27-2006 11:02 PM
