Concrete In Every Fence Post Hole? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-10-2011, 09:34 PM   #1
concrete in every fence post hole?
To build a 6' privacy fence do you think it would be overkill to put concrete in each fence post hole? Or would just on the corners and end posts suffice?
I've read you don't even need concrete - but I am going to be hanging two 11' wide custom gates (split into two 5.5' sections) so I want that extra support. And I don't want any chance that this fence is going to sag 5 years from now.
thanks
snosurfa7 is offline   Reply With Quote
Old 08-10-2011, 09:40 PM   #2
Rewards Points: 1,016
I use concrete in every post hole - the mix in the hole quick setting variety. I also like metal posts rather than wood posts - last much longer. There are metal bracket that allow the connect of the wood stringers to the metal posts. Fences usually die from post rot - so work that problem for a long lasting fence.
____________
Vince
Old 08-11-2011, 11:44 AM   #3
AGWhitehouse's Avatar
Concrete every hole and it likely won't sag in 5 years.
may want to pay a little more attention to the posts holding those 5'-6" gates. That kind of weight swinging regularly will loosen up a standard post footing pretty easily over time. If it's a "use it a few times a year" kind of gate, then a standard footing will suffice if you put a rolling wheel on the end of the gate leaf to help offset the cantilevered weight.
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
Old 08-15-2011, 07:43 PM   #4
Those gates will be used somewhat frequently...I was going to but some bigger end posts to support these gates, dig a little deeper, put a wheel, and also a gate brace kit...but if you or anyone else has better ideas please let me know but yeah, I have seen way too many fence gates sag
Old 08-15-2011, 08:47 PM   #5
In my experience I've found that concrete speeds up the deterioration of wood posts. An extra step i take is to dip or paint the bottoms of the posts with roof cement before putting them in the ground to insulate them from the lime in the cement. I have fences that have been up for more than 30 years.
The Hammer is offline   Reply With Quote
Hole in concrete basement wall... viggen Building & Construction 1 06-06-2011 09:32 AM
How to replace a loose fence post preciouschristy Building & Construction 2 05-14-2011 06:06 PM
Attaching fence post to side of retaining wall? Drew328i Landscaping & Lawn Care 5 06-01-2010 08:53 AM
6x6 Cedar post rot stanltod Carpentry 2 06-21-2009 05:54 PM
Concrete around treated fence post or not? ChimChim Building & Construction 10 04-19-2009 09:21 AM
