Concrete Driveway Repair - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-27-2011, 01:19 AM   #1
CapnHawk's Avatar
Rewards Points: 20
I had to cut my sloping concrete driveway in order to replace my water service mainline. I went from galvanized to copper for the water service. Now, I'm left with an open trench 12" wide by 6" deep by 17' in length. What would be the proper patching material for this repair? Rebar necessary? Any help/advice is greatly appreciated!
CapnHawk is offline   Reply With Quote
Old 12-27-2011, 01:36 AM   #2
Residential Designer
AndyGump's Avatar
Rewards Points: 688
Send a message via Skype™ to AndyGump
Being as you are in LA you probably don't need permits for this. The present slab was probably not on any sort of base material either, you can probably just pour new conc. on the bare earth.
It'll never look good but you could drill 1/2" holes into the ends of the slab and install #3 rebar, staggered 24" O.C. Then pour the new conc.
Andy.
AndyGump is offline   Reply With Quote
The Following User Says Thank You to AndyGump For This Useful Post:
CapnHawk (12-28-2011)
Old 12-27-2011, 01:59 PM   #3
Retired carpenter
The patching material would be plain concrete. Make sure that the fill around the new pipe is well compacted, or it will crack. Using rebar sideways, like Andy suggested, will help to keep your new concrete from sagging and busting your new pipe.
abracaboom is offline   Reply With Quote
The Following User Says Thank You to abracaboom For This Useful Post:
3" gap between concrete driveway and concrete garage floor - help! frankrizzo Flooring 0 11-23-2010 08:07 AM
Concrete reinforced block foundation repair questions CCHanna05 Building & Construction 2 07-06-2010 03:57 PM
Best way to repair concrete retaining walls? ohman Landscaping & Lawn Care 2 06-25-2009 11:45 AM
Concrete driveway with rock salt finish? imola ghost Building & Construction 11 10-27-2008 12:11 AM
Garage concrete and driveway asphalt repairs creamaster Building & Construction 4 07-12-2008 10:51 PM
