Concrete Driveway - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-09-2011, 04:27 PM   #1
concrete driveway
I,m having a new driveway installed. The old was completely removed and the new is going in in sections. There was cement left over from the first pour and it was put in the second section to a depth of about 2inches. My contractor says it's OK to just pour the other 2 inches of the second section on top of the 2 inches already there. Is that OK do do?
Bruce Salisbury is offline   Reply With Quote
Old 07-09-2011, 05:33 PM   #2
concretemasonry's Avatar
Rewards Points: 2,640
No way. That is just not the right thing for a constractor to do.
It is his fault since has already proven he does not know how to order.
How do you know if he even had enough brains to order the right mix?
concretemasonry is online now   Reply With Quote
The Following User Says Thank You to concretemasonry For This Useful Post:
Bruce Salisbury (07-10-2011)
Old 07-10-2011, 05:33 AM   #3
Rewards Points: 4,794
depends - how soon was/will the 2nd section be placed ? IF it was less than an hr AND the old could be safely consolidated the new conc, i might agree & think dick might also,,, the manner of your post suggests otherwise - if so, see dick's answer
The Following User Says Thank You to stadry For This Useful Post:
concretemasonry (07-10-2011)
Concrete Driveway - Asphalt Over Top? mark2741 Building & Construction 1 03-22-2011 03:42 PM
3" gap between concrete driveway and garage floor need to fill frankrizzo Building & Construction 0 11-23-2010 08:08 AM
3" gap between concrete driveway and concrete garage floor - help! frankrizzo Flooring 0 11-23-2010 08:07 AM
Should concrete driveway slab be thinner on the edge by the forms? Studly Building & Construction 6 09-14-2009 09:24 AM
