Old 07-07-2009, 01:30 PM   #1
Concrete Deck Post removal
Hi: I am new to this forum. We have recently removed a 24" high wood deck to replace with a set of stairs and a patio . All the wood has been removed and we are left with 8 concrete sono tube forms sticking up from the ground (clay based). They are approx 3 - 4 feet deep into the ground. How does one go about removing them? Do we cut them off at the base? Do we jackhammer them out? Not sure. I got a quote to get a bob cat in to remove and dispose of them and the cost was exorbitant? ($600 for the bobcat & removal - & $400 for the bin and dispose).
Any help or suggestions would be most appreciated.
Stuck
cookie300 is offline   Reply With Quote
Old 07-07-2009, 04:20 PM   #2
Is removing them necessary? Will the patio be lower than the top of the piers? What is the material for the new patio? Can you use any of the existing piers to support the new stairs? Pictures might help us make a few suggestions.
Rege
RegeSullivan is offline   Reply With Quote
Old 07-07-2009, 04:29 PM   #3
Xtreme DIY'r
I've used a sledghammer on some to break the concrete up
Old 07-07-2009, 04:59 PM   #4
Tileguy
Bud Cline's Avatar
Break them off (to grade) then pour the new patio over them at that point.
Rent a jackhammer to demo the collumns then discard the chips gradually via your trash disposal service.
Depth of Concrete Piers for A Deck marathonman Building & Construction 3 05-18-2009 05:22 PM
Bad Concrete in Fence Post Holes - Advice? bcrenshaw Building & Construction 2 08-24-2008 12:21 PM
Poor Deck Post Anchors Schnelltdi Building & Construction 5 04-06-2008 12:14 PM
replace porch post on concrete slab maa40 Building & Construction 2 03-23-2008 11:50 AM
Concrete deck -- rotting floor joists jwill Building & Construction 6 09-05-2007 09:01 AM
