Old 09-23-2007, 02:16 PM   #1
Concrete Deck Footings Bumpy
When we had our 12 inch round footings installed for our deck the tops of the concrete weren't smoothed level. They are not really so crooked, but are quite bumpy (not like the nice clean flat smooth surface you see in the DIY books). Wondering what a good way would be to get them flat and level enough to sit a post on properly. Also, what is the rule-of-thumb for when you need to move to a 6" wooden post from a 4". This is a 2-level deck and 8" joists will be sitting on a laminated 2x(2x10) beam. Thanks in advance! M
Melanie337 is offline   Reply With Quote
Old 09-23-2007, 02:40 PM   #2
concretemasonry's Avatar
Location: Minnesota - Longitude 45.057 Latitude -93.074
You should have inserted the appropriate galvanized steel ianchors into the concrete before it was set. This will provide a good anchorage to resist shear and uplift. Without anchorage an unloaded deck can be lifted and shilfted by the wind, depending on the direction.
The size of the post (4x4 or 6x6) is determined by the load and the necessary width to handle the connections above.
Did you have a permit for the design and the construction. Did you have an inspection?
concretemasonry is online now   Reply With Quote
Old 09-23-2007, 03:04 PM   #3
Unfortunately things got done in a hurry and the anchors did not get installed. The "code" people are okay with drilling anchors in after (where we are now) and the deck design is in progress. So.....what can we do about the bumps?...drill and install those U-shaped thingies...it would still not sit straight. Is there a good way to level/smooth the footings first? Thanks! M
Old 09-23-2007, 08:55 PM   #4
Extreme DIY'r Adk's, NY
How much can it be off on 4"?
I use something like these.
http://www.strongtie.com/products/co...U.html#gallery
crecore is offline   Reply With Quote
Old 09-24-2007, 07:42 PM   #5
You can smooth out the bumps with a grinder and a masonary disc.
Ron
Old 09-24-2007, 08:09 PM   #6
Just use a repair mortar or non shrink grout to level it. Cheap easy, and plenty strong.
Tscarborough is offline   Reply With Quote
Old 09-24-2007, 09:11 PM   #7
Thanks for all the help!! M
More On This Topic
We are going to be talking about our tire pressure now and basic quad riding. We are going to go ahead and start with finding the tire pressure on your tire. It will be listed somewhere along the side around here, all's you have to do is look for it. Now... Read More »
A scissor jack is a primary tool used when changing motorcycle tires; learn how to use one in this video on DIY motorcycle maintenance for flat tires. Read More »
Hi. I'm Melina and welcome to Expert Village. Today we're going to make a polymer clay bowl. For this next step we're going to add the foot that we made before. This is the little round bottom piece that we had made before. And now we're going to attach... Read More »
Sidewalks break down over time due to wear and tear, and as they expand and contract due to changes in the weather. If you are ready for your next sidewalk replacement, the steps below will help you achieve a long lasting result that you can be proud of. Read More »
Learn how to grind metal parts smooth when doing body work and restoring a car in this free DIY car-restoration video from our expert mechanic and body shop owner. Read More »
Concrete deck -- rotting floor joists jwill Building & Construction 6 09-05-2007 09:01 AM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 02:32 PM
Concrete shed footings in a marsh/wetland? tigerbalm2424 Building & Construction 11 03-27-2007 07:37 PM
refacing rubble concrete foundation footings Buck Building & Construction 2 10-25-2006 01:36 PM
Deck post footings Outbacker Building & Construction 8 02-11-2006 06:20 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
