Concrete Curing In Post Holes - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-19-2008, 08:44 AM   #1
Rewards Points: 256
Concrete curing in post holes
I've read the post this week about a slab curing in MN, and I'm in MI where its really no different temp wise (high of 35 all week).
I dug 9 post holes 48" deep 2 weeks ago when it was 70 degrees and now need to get the posts set. Is it advisable to attempt to set them now that the weather is so cold? I'm really hoping this doesn't have to get put off until spring!
moneymgmt is offline   Reply With Quote
Old 11-19-2008, 08:52 AM   #2
joed's Avatar
Rewards Points: 11,516
If the holes are not frozen then I don't see any problem. The ground should keep the concrete from freezing.
Old 11-19-2008, 08:52 AM   #3
RippySkippy's Avatar
It's not too late for the cure...especially if you were to cover the top with straw, tarp, plastic etc, it will help to keep the heat in and lessen the impact of temperature changes from the surface.
Are the post wooden? If so there's quite a bit of support to not set them in concrete rather use crushed stone as it will allow moisture to move away from the post.
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 11-19-2008, 08:55 AM   #4
Registered User
Termite's Avatar
Post holes won't be much of a problem, as long as the inside face of them isn't frozen solid, from being exposed for a while. Even if the soil is frozen for an inch or so, the heat of the concrete will thaw that very quickly. Placing concrete doesn't concern me at all because the heat of the earth will keep things reasonably warm. Just cover the tops with straw or blankets.
Old 11-19-2008, 08:55 AM   #5
Rewards Points: 256
all of the posts are hollow vinyl 4x4 but two of them will have a treated 4x4 down the middle for support as gate posts. The inside of the holes shouldn't be frozen, I've kept "lids" on them so nobody should accidentally fall in!
Thanks for your help!! Guess this means I'll be mixing and pouring concrete instead of hunting after work
Old 11-19-2008, 11:01 AM   #6
Keep in mind that earth is a good insulator. Concrete gives of heat when it is setting. The heat from the curing is trapped but the earth around it. Just the top would be affected and probably not a lot since the heat would rise and keep the top part warm. But covering it would not be a bad idea.
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
Bad Concrete in Fence Post Holes - Advice? bcrenshaw Building & Construction 2 08-24-2008 12:21 PM
Concrete piers for post & beam foundation jpecor Building & Construction 1 08-01-2008 01:27 PM
Engineering help request: drilling holes in a deck joist, supported by a post Deck Building & Construction 14 05-31-2008 11:16 PM
Proper Post on Concrete Procedure Dallas Building & Construction 3 01-05-2008 08:20 AM
Post in or post on concrete cibula11 Building & Construction 5 06-07-2007 10:39 PM
