Concrete: Cure Time Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-07-2010, 09:05 PM   #1
Concrete: cure time question
I'm pouring a 3000 psi concrete footer for a block wall.
1) how long should the footer cure before building an 8 course block wall on top? (I will be drilling holes in the footer to epoxy vertical rebar for the block.
walkman is offline   Reply With Quote
Old 03-07-2010, 09:40 PM   #2
joed's Avatar
Rewards Points: 12,848
Put the rebar in when you pour the footing.
Old 03-07-2010, 10:31 PM   #3
Rewards Points: 1,016
X2, install the rebar during the pour - that epoxy is expensive
Couple days to cure.
Old 03-08-2010, 09:22 AM   #4
concretemasonry's Avatar
Rewards Points: 2,608
I have seen the rebar dowels pushed in or set when the strip footings are poured. Block (the first course or two are sometimes laid laid late the day of the pour since the lines and batter boards are still in place. It is also done to proect from an overnight rain that could cover the footings in the excavation with mud and water.It is much easier to make the final squaring of the foundation if the first course or so are in place, but adjustments are usually not necessary if the footings were laid out from a proper reference.
Dick
concretemasonry is online now   Reply With Quote
Old 03-08-2010, 09:57 AM   #5
A week should be fine but put your steel in BEFORE pouring
BobKbta is offline   Reply With Quote
Old 03-08-2010, 06:27 PM   #6
Rewards Points: 95
Place the steel before pouring like suggested. And lay the block the next day. Or if you pour early in the day you can lay a few courses that afternoon like dick said.
NJ Brickie is offline   Reply With Quote
Question on hanging new door in concrete block wall dave11 Carpentry 7 11-12-2009 07:21 PM
Living room extension - concrete pad question tpagel Building & Construction 7 03-06-2009 11:57 AM
epoxy coat and resurfacing concrete cure time questions ?? waltereo Flooring 3 10-04-2008 11:43 AM
Sidewalk Meets Concrete Truck Question craigNeasttx Building & Construction 5 03-24-2005 11:40 PM
Concrete question Daniel O'Connor General DIY Discussions 1 11-22-2004 02:54 PM
