Concrete Curbs - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-12-2009, 02:14 PM   #1
Concrete Curbs
We will be installing concrete curbs in our subdivision entrance because so many cars and trucks drive off the road on the turn. Most of the damage is by garbage trucks and school busses. Question: should we use 5000psi concrete instead of 3000 psi concrete due to the expected contact of the trucks with the curbs?
Nick G is offline   Reply With Quote
Old 10-12-2009, 04:55 PM   #2
Licensed P.E./Home Insp
Aggie67's Avatar
Rewards Points: 826
Your state DOT website will have drawings and specs for roadway curbs. Check out their website and download the specs and details. It's all free. Your tax dollars at work.
Aggie67 is offline   Reply With Quote
Old 10-12-2009, 08:05 PM   #3
Rewards Points: 4,648
you CAN always exceed specs,,, place curbs outside suspect vehicle's norrmal turn radius.
Old 10-12-2009, 08:58 PM   #4
Rewards Points: 95
Not always true. Certain government contracts specify a certain mix of concrete that MUST be used.
NJ Brickie is offline   Reply With Quote
Old 10-13-2009, 02:51 AM   #5
lemme expand, then,,, brickie's correct in posting that all contracts specify certain approv'd mtls ( even by brand name ) that'd proven ( usually by astm tests ) acceptable, eg concrete mix design ( slump, wtr/cement ratio, compressive strength limits w/i stated time periods ),,, in public work, there generally are other substitutes allow'd than spec'd covered by the ' or approved equal ' phrase,,, we never had submittals rejected that increased performance in the final product to owners such as nj tpke, garden state pkwy, dot, city of newark, port authority, or counties.
Old 10-13-2009, 05:32 PM   #6
World's Tallest Midget
Mort's Avatar
Rewards Points: 692
Our curb mixes are 4000psi in this area, FWIW.
I hate signatures.
Mort is offline   Reply With Quote
Old 10-13-2009, 06:04 PM   #7
concretemasonry's Avatar
Rewards Points: 2,608
If this a subdivision entrance off a public /country/municipal/county/state road?
If you there may be some other requirements. In some cases organizations (government & utilities) do not want over-designed/over-built improvements that interfere with access and maintenance. Often utilites (which can be very dense at a corner or intersection) can have a major effect on the best possible way to build.
I lived in a town in MI that had a requirement that there could be no reinforcement (fibermesh was weak and was acceptable) in a sidewalk or the driveway apron between the sidewalk and the street because of the difficulty of removing the concrete. Obviously, the curbs had to be done according to city standards, so they had an idea of what they might encouter id a cut or mantenance was required.
If you are in a freezing climate, a higher strength (4000 to 5000 psi) with air entrainement (4%-6%) would probably be required for durability. Reinforcement is a different animal becaue that could entail removing more concrete than necessary.
Sometimes stronger is not always the best way to go.
Dick
concretemasonry is offline   Reply With Quote
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 06:25 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
Help!: 4" concrete over 2' dirt over 7/8 wood planking! agent99 Flooring 4 04-28-2009 08:21 AM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 01:32 PM
Rising concrete curbs around flower beds degarr Landscaping & Lawn Care 1 05-02-2006 06:22 PM
