Old 04-22-2011, 07:55 AM   #1
Concrete cracks
I am having a home built from preformed concrete walls. Upon inspection of the work we have identified a crack in the main doorframe area, as documented in the attached photo. While we will have an engineer inspect the work and specifically this defect, I am interested in comments from anyone with concrete expertise. Can this be repaired permanently with epoxy injection?
koos123 is offline   Reply With Quote
Old 04-22-2011, 03:01 PM   #2
Concrete cracks
yes, sufficiently & permanently IF the steel reinforcement is properly in place AND the operator knows his stuff am curious - was this piece cracked on delivery, while in the yard, during placement, OR after installation ?
taxpayers voting for obama are as idiotic as chickens who voted for Col. Sanders !
if you hear it from a guy in the apron store, be VERY suspicious the mtl/method will work,,, when it time to build something together, they won't answer phones NOR help
itsreallyconc is offline   Reply With Quote
Tags
concrete, crack
concrete drive and walk 7echo Landscaping & Lawn Care 12 04-22-2011 06:03 PM
concrete cracks Wiscbldr Building & Construction 15 04-19-2011 07:20 PM
Creating a flat floor on an angled concrete floor? Magno Building & Construction 1 04-14-2011 06:42 AM
Foundation cracks drain tile fiveoh018 Plumbing 3 06-26-2010 03:55 PM
Very bumpy concrete floor that is not level cgcaudle Flooring 1 08-31-2008 05:04 PM
