Concrete Cracking - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-27-2010, 05:19 PM   #1
concrete cracking
Hello,
I poured a 24x40 concrete approach about 2 months ago. I cut lines in it the next day and sealed it within the week. I know concrete cracks, but when the slab gets wet, there is a darkened web all through out. I have noticed some of the cracks are starting in the darkened areas. It kind of worries me that it will keep going. I posted a picture since it's hard to explain, if I did it right anyway. The only thing I can think of doing this, is the sealant. I have done concrete work off and on before, but never use sealant. This is the first time I have seen something like this. Any information would be appreciated. Thanks.
brock1093 is offline   Reply With Quote
Old 07-27-2010, 05:23 PM   #2
Also, the slab looks pretty normal when dry. Here is a picture of the whole slab.
Old 07-28-2010, 12:54 AM   #3
Registered User
Rewards Points: 4,894
We have a couple of concrete experts here, but not me. While you wait for them, cruise around on this site: http://www.todaysconcretetechnology....-cracking.html
Be safe, Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
ebarring (08-03-2010)
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 07:25 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
how to fill the gaps between concrete blocks? micapavlov Building & Construction 4 01-03-2010 05:53 PM
Help!: 4" concrete over 2' dirt over 7/8 wood planking! agent99 Flooring 4 04-28-2009 09:21 AM
Concrete slab cracking sluggermike Flooring 12 10-19-2007 03:40 AM
