Concrete For Columns - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-25-2010, 10:54 PM   #1
Concrete for columns
I bought a set of roman columns made of concrete moldings. each column is divided into 4 pieces. the seller asked me to use mortar to stack them on top of each other. Having never done any kind of masonary work in the past, I am wondering what kind of mortar to use. the column pieces are about 100lbs each.
shuss is offline   Reply With Quote
Old 04-26-2010, 07:29 PM   #2
Rewards Points: 5,336
How high will these columns be? Were do you live? Earthquake, tornado or hurricane zone?
You might need more then simple mortar to keep them upright.
Ron
Old 04-26-2010, 09:58 PM   #3
these are 6 feet in height. the blocks are about 20 inches each and they will be stacked upon each other.
There are no hurricanes, quakes or tornadoes in this part of AZ.
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 06:25 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
how to fill the gaps between concrete blocks? micapavlov Building & Construction 4 01-03-2010 04:53 PM
Help!: 4" concrete over 2' dirt over 7/8 wood planking! agent99 Flooring 4 04-28-2009 08:21 AM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 01:32 PM
