-   -   Concrete Columns? (http://www.diychatroom.com/f19/concrete-columns-2220/)
econdave 04-07-2006 07:48 PM
Concrete Columns?
I am building a deck using 8" sonatube 4 ft deep. I need to figure out how many 80lb bags of ready mix concrete to buy to fill each tube.Can you tell me how I determine this number. There are 12 tubes to be filled all together. Thank you.
tgeb 04-07-2006 08:46 PM
Well the formula for the area of a circle is:
Pi X radius squared which in your case would be,
radius 4" or .34 squared = .1156
pi = (3.142)
3.142 X .1156 =.3632
.3636 X 4' of depth of tube = 1.45 cubic feet per tube
1.45 cubic feet per tube X 12 tubes = 17.43 cubic feet.
How many cubic feet are in an 80 lb. bag of sacrete I have no clue, but it should be listed on the bag.
If I were you I would get a few extra bags, it is surpising how much you can loose on the ground when filling those things.
Tom
Somebody check my math please. :)
I have been known to order way too much, and way too little concrete. Just ask the dispacthers. :)
bob the builder 04-07-2006 08:59 PM
That sounds pretty good to me, but rounding your #'s off makes it a little off. I came up with 16.75404 cu. ft. I Would just say that it takes 2.4 bags per pier x12=28.8 bags. Plus whatever waste you want to account for.....
Bob
tgeb 04-07-2006 09:21 PM
Too many decimal points for me Bob. :o
Thanks for the verification. :)
Tom
econdave 04-08-2006 07:08 AM
concrete colums
thanks for you help, I will buy extra for waste like you said. What a great forum.
econdave 04-08-2006 07:33 AM
TGEB ? Concrete Colums.
after reading your reply, I was wondering why you used a radius of 4" wouldnt I use 8"? since the tubes are 8". I am not questioning your knowledge, just want to be able to figure this out on my own if needed. Thank you again for your help...
tgeb 04-08-2006 10:56 AM
8" is the diameter of the tube, 1/2 of the diameter would be the radius, 4" :)
Tom
