Concrete Buildup On Patio - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-29-2010, 03:12 PM   #1
Rewards Points: 12
Concrete buildup on patio
I have a cast iron manhole in my brick patio. The paver guy bordered the manhole with cement (about 2" all around), but the level of the cement is about 1/8" to 1/4" lower than the bricks and the flange of the manhole. I want to bulidup the level so that it is all flush with the patio surface. I've done stucco before, but always over fresh cement. This cement is about 5 months old, and pretty rough. Should I put bonding down first, or just wet and finish? My final goal is to stain the cement a brick color and seal so that it blends in with the patio.
TIA
pianodude is offline   Reply With Quote
Old 06-29-2010, 08:33 PM   #2
TIA
If you live someplace where it freezes in the winter, don't worry about it being low, as it won't be long before the concrete ring breaks up and you will have to replace it properly!
Old 06-30-2010, 12:23 AM   #3
Rewards Points: 12
I'm in Miami FL. Freezing is not an issue.
Old 06-30-2010, 05:40 PM   #4
Lucky you! Send me your address and i'll come down in February and help you level it off!
Will pay for patio advice! :) DirkPitt Landscaping & Lawn Care 6 07-31-2009 03:35 PM
Building deck over concrete patio stro77 Building & Construction 8 06-25-2009 05:21 PM
repairing concrete patio flooring & attached walls 1655graff Remodeling 2 01-21-2009 01:21 PM
Concrete Patio drainage problem lakekids Building & Construction 5 07-17-2008 06:27 AM
Extending Concrete Patio Slab bobo Building & Construction 6 04-17-2008 01:17 PM
