Concrete Board Siding Is Sweating - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-28-2011, 10:17 AM   #1
Concrete board siding is sweating
I have attached a picture of my house when the temperature gets cooler at night or early morning I see my house is wet but only where the insulation is as you can see each wall cavity from the wetness. Is this a problem?
ssleek is offline   Reply With Quote
Old 11-28-2011, 10:32 AM   #2
Rewards Points: 502
looks like you have no insulation or vapor barrier. I'd call that a big problem if you care about heating bills
forresth is offline   Reply With Quote
Old 11-28-2011, 11:51 AM   #3
Chaos Engineer
Big N8's Avatar
Rewards Points: 152
More information is needed.
Location?
Age of home?
Big N8 is offline   Reply With Quote
Old 11-28-2011, 11:54 AM   #4
Home was built in 2002 and has blown insulation in wall but not sure about the vapor barrier I was thinking that may be the problem. Location of home is Indiana.
Old 11-28-2011, 11:56 AM   #5
Chaos Engineer
Big N8's Avatar
Rewards Points: 152
does the lower part of the wall have the issue as well?
Old 11-28-2011, 12:05 PM   #6
Yes pretty much from floor to ceiling on each floor shows the moisture. I have searched on google to find nothing on this issue.
Old 11-28-2011, 12:17 PM   #7
Rewards Points: 5,336
If it's a vapor barrier issue, you can easily test it. Tape up a t least a 4 mil plastic sheet along one wall and seal all the edges. See if it changes the moisture on the outside wall.
After the insulaion was blown in, was the coverage verified by thermal scans?
Ron
B. Franklin 1759
Old 11-28-2011, 12:21 PM   #8
Rewards Points: 252
Does this happen all the time? Do any other surfaces experience this (car, grass, etc)? I would say it is dew. It only forms where there is insulation because the studs transfer the heat from the house, which is enough to eliminate the dew.
shazapple is offline   Reply With Quote
Old 11-28-2011, 12:22 PM   #9
Had an energy audit 2 weeks ago and it looks like with the infrared scan that most the insulation did not drop too bad. Just so I get this right on the inside tape the 4 mill plastic to the drywall and seal edges for a test.
Old 11-28-2011, 12:28 PM   #10
I do not see this every night but this is the first winter going into this house. I do have a mold issue in the house and I hope this will not cause mold inside the walls behind insulation. I hope it is just dew as I have never had hardi plank siding before.
Old 11-28-2011, 12:29 PM   #11
Yes. Wall to wall, floor to ceiling. Cover everything, including the windows.
Do your neighbors have this condensation problem on their houses?
Ron
B. Franklin 1759
Old 11-28-2011, 01:00 PM   #12
I dont live immediately near anyone but have never seen this issue before and also on the neighbors house down the road I am the only one with hardi plank concrete board siding.
Old 11-28-2011, 07:11 PM   #13
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,334
this is caused by heatloss through the wall, by the looks of the wall i have a strong feeling the siding installers didnt install a proper rain screen...
if you look at your roof in the morning you can see the same sorta thing going on as to where the edges of each sheet of plywood are. normally its caused by insufficient insulation
woodworkbykirk is offline   Reply With Quote
Old 11-28-2011, 07:51 PM   #14
Anything I can do to fix? Any other issues besides heat loss?
Old 11-28-2011, 07:56 PM   #15
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
As the concrete will never completely dry out, there isn't much you can do.
titanoman is offline   Reply With Quote
High Rise Building methods - US versus Oz - Steel versus Concrete Jado Off Topic 17 09-15-2011 08:47 PM
Vapor barrier in tub/shower stall with exterior wall... OK to install Schluter-KERDI over concrete board? tzinho Tiling, ceramics, marble 1 01-24-2011 08:58 PM
Concrete Patio too close to siding??? ddave23 Landscaping & Lawn Care 2 07-26-2010 06:51 AM
Hardi board plank siding over T1-11 bluefitness Building & Construction 3 12-19-2008 07:55 AM
Hardie Board Textured siding instead of Stucco wesc Building & Construction 5 03-22-2008 12:43 PM
