Concrete Blocks On Garage Slab - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-17-2010, 06:57 PM   #1
concrete blocks on garage slab
I'm getting ready to build my garage finally! I want to lay a row of 6" blocks around the perimeter of the slab to keep the walls up and away from moisture. Some say that I should lay them 2 high instead of one, for more strength. Why wouldn't one row be strong enough? They will be anchored to the pad with the appropriate anchor bolts. Any advice?
bushmoose is offline   Reply With Quote
Old 10-17-2010, 07:13 PM   #2
concretemasonry's Avatar
Rewards Points: 2,608
No need to go more the one block high.
Technically, the 6" block is stronger than the wood frame above, but the added strength is not needed.
Around here, block stem walls are commonly used and the block are laid up to about 8 " above the planned slab elevation. This allows the anchor bolts to start below the slab level and then project through the sill plate and hold everything together and resist uplift. After that, a 4" a floating slab can be poured and sloped for the desired drainage (flat, to the overhead door or to a floor drain). The floating slab can be put in after the garage is enclosed and the weather is under control. The slab has wire and is air entrained because of the temperatures and salt droppings.
You are smart to have the block curb because it makes it easy to sweep out or hose and wash out and get the wood above the soil without collecting water around the garage.
Dick
concretemasonry is offline   Reply With Quote
Old 10-17-2010, 07:52 PM   #3
I plan to just pour a floating slab on grade and lay the blocks on the slab afterwards. It's all approved with the building inspector so that part is good to go. I just wanted some opinions about using 1 row instead of 2 as some fella's have told me to do. Thanks for the reply!
Old 10-17-2010, 08:08 PM   #4
Concrete & Masonry
Rewards Points: 580
Simple logic tells me that 1 row would actually be more stable than 2. Plus you'll be hard pressed to find anchor bolts readily available for 2 courses.
jomama45 is online now   Reply With Quote
The Following User Says Thank You to jomama45 For This Useful Post:
bushmoose (10-17-2010)
Old 10-18-2010, 06:56 AM   #5
Household Handyman
Rewards Points: 1,408
"I plan to just pour a floating slab on grade"
No footers around the perimeter? Not sure I would just pour a slab without footers. That's a lot of weight on that outer edge. I did my shop building, unattached to the home, this way with one course of block. Never have regretted it. We tried very hard to slope the floor from back to front towards the larger shop doors for drainage. My plans were to use a garden hose, brush, etc. to clean the floor occasionally. All that went astray when the wifey and son decided that old Dad had built them a "storage building". David
Old 10-18-2010, 07:10 AM   #6
There will be an 8" x 16" footing sloped to the floor, which will be 5" thick. I plan to run 2 course's of 5/8" rebar around the footing with 3/8" rebar 2' oc throughout the floor.
I've already given orders that it will NOT be used as storage and the sign will be up "no gurls aloud" to confirm that
Old 10-18-2010, 02:37 PM   #7
Registered User
Rewards Points: 5,516
Remember the sill sealer unless you use a v.b. under the slab: http://www.greenbuildingadvisor.com/...-building-code
Don't extend the sheathing onto the block or it could wick moisture up into your framing. Leave a gap between sheets, awww, you know the rest.
Gary
Old 10-18-2010, 05:29 PM   #8
Rewards Points: 4,656
that's a ' thickened edge ' slab also called a monopour or unipour,,, 1 row of block's fine,,, we would fill the cells w/grout
Attaching Blocks to Concrete, then wall to that jimmyfloyd Building & Construction 4 07-15-2014 07:52 PM
How to cut a hole in a concrete floor slab tomseeley General DIY Discussions 7 06-10-2009 02:32 PM
Basement Garage with Concrete Slab: To Vent or not to Vent N-GA-Homeowner Remodeling 3 05-29-2009 06:13 AM
Filling concrete cinder blocks Clutchcargo Building & Construction 7 07-25-2008 06:54 AM
Garage concrete and driveway asphalt repairs creamaster Building & Construction 4 07-12-2008 10:51 PM
