Old 12-28-2006, 07:45 PM   #1
Concrete Block Wall
I am looking at putting in a cinder block wall (50' x 6'). It is in Calif. and in a no freeze area. What is needed for the footing? Depth, width, filler, and re-bar? I think that it needs to be 12" deep and 16" wide with 6" of crushed rock as the base, not sure on the re-bar requirement. How far am I off?
Robert
rag4rdd is offline   Reply With Quote
Old 12-28-2006, 09:13 PM   #2
concretemasonry's Avatar
Concrete Block Wall
Most municipalities have requirements for concrete block privacy walls since they are so common and some areas will not accept wood or "grapestake" fences. Contact your local building office.
The thing they worry about is the wall becoming a sidewalk on top of some kids during an earthquake.
concretemasonry is offline   Reply With Quote
Old 02-15-2007, 12:41 AM   #3
Concrete Block Wall
Robert
is the wall a retainer? haw much water does your site accumalate?
Im in az and Im currently building a double block wall with 2 planters each wall is 8" w x 4ft x 150ft the footing reguired here was 10" x 12" x 150ft I didndt require a bed of stone hope I helped.
orenawilliam is offline   Reply With Quote
Texture Coating for a New Concrete Block outside Wall scholin Painting 2 12-01-2007 07:03 AM
Best way to handle this - furring out concrete freeze wall J187 Building & Construction 10 05-14-2007 06:17 PM
Concrete cement wall leaks and paint BobFar Building & Construction 7 04-16-2007 06:22 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
concrete wall glseagraves Building & Construction 3 06-16-2006 09:58 AM
