Concrete Block Repair - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-07-2009, 11:44 AM   #1
Rewards Points: 109
Concrete block repair
I have to patch the face of a concrete block on my foundation. What is the best material to use as far as something with a good bond?
hitmehhh is offline   Reply With Quote
Old 03-07-2009, 01:11 PM   #2
Remodeling Contractor
concrete works good. Just use a bonding agent over a clean and dry foundation wall. Sand mix, not gravel mix.
Old 03-07-2009, 01:23 PM   #3
Rewards Points: 95
How big is the patch you are making? Length, width, and depth? Is the wall painted? Will it be painted?
NJ Brickie is offline   Reply With Quote
Old 03-07-2009, 01:24 PM   #4
I think he is talking about parging the foundation.... Need some more info here.
Old 03-07-2009, 02:43 PM   #5
Rewards Points: 109
concrete block repair
Its bare block . The weather over the years has gotten to it . Its about a spot 4X7 and abut 1/4" deep.
Old 03-07-2009, 10:43 PM   #6
Rewards Points: 95
A patch that small I would just use a mortar mix. Go to lowes/ HD buy Mason Mix. You are not really looking for strength in this situation, you are looking for bond. Be sure to clean the area very well. Lightly dampen the block and trowel it on. Let the mud set up for alittle while then rub it in a circular pattern with a lighty dampened sponge. If you have a large sponge like the type to wash a car with that will work well.
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 07:25 PM
Concrete Block Foundation Questions project_guy Building & Construction 1 05-09-2008 10:16 AM
Can foam sealer be used to seal the spaces in concrete block? marksto Building & Construction 6 04-21-2008 08:48 AM
Concrete block - bond pattern tvoltz Building & Construction 1 06-11-2007 07:36 PM
