Old 06-10-2007, 11:32 PM   #1
Concrete block - bond pattern
FOlks,
I'm adding an addition that includes a full basement. 2 questions on using concrete block.
1. Any advice on how to bond the new block to the old poured foundation walls?
2. For size reasons, three of the four walls in the new foundation are not sized as multiples of 8" such that whole and half blocks can be used. Each will require a short block to fill the space. How to I use a short block and still keep a running bond pattern?
tvoltz is offline   Reply With Quote
Old 06-11-2007, 07:36 PM   #2
1. Drill rebar into your horizontal bond beams.
2. Modular for CMU is the same Modular as for wood. Why would you not size it on a multiple of 8"? Anyway, there will just be a short piece on every course. There should be no piece less than 4" wide however, so you may have to have 2 odd size pieces per course.
Tscarborough is offline   Reply With Quote
Sleeve options for plumbing through concrete? Bruce L Plumbing 6 06-14-2008 10:38 AM
Texture Coating for a New Concrete Block outside Wall scholin Painting 2 12-01-2007 07:03 AM
Concrete Block Wall rag4rdd Building & Construction 2 02-15-2007 12:41 AM
Concrete Block under the Front Door Robinjail Building & Construction 1 06-27-2006 11:04 PM
