Concrete Bits - Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-23-2012, 06:54 PM   #1
Solutions (handyman)
Rewards Points: 362
concrete bits - question
I am drilling into a very old foundation and the standard concrete bits don't do anything. I'm using a hammer drill and the bits are from HomeDepot. I think they would do fine on brick and cment blocks but the foundation is solid. Any suggestions?
Mark Harvey is offline   Reply With Quote
Old 11-23-2012, 07:01 PM   #2
Rewards Points: 12,818
Sure the drills running in the right direction?
Unless I'm hitting a stone in concrete I've never had on not work.
What size hole?
What drill are you trying to use?
Old 11-23-2012, 07:06 PM   #3
Rewards Points: 362
drill bits
I'm using a Dewalt 1/2" also I have a local brand Mastercraft hammardrill. The hole size is 3/16. I agree I may be hitting a rock but I would think it would shatter after a while.
Old 11-23-2012, 07:27 PM   #4
DIY staff
Rewards Points: 7,174
Try Bosch masonry bits---they are the best ones you will find without going to a specialty house---
I use them all the time and go through some tough materials----
The Following 4 Users Say Thank You to oh'mike For This Useful Post:
packer_rich (11-25-2012), princelake (11-23-2012), user1007 (11-24-2012), woodworkbykirk (11-24-2012)
Old 11-23-2012, 08:32 PM   #5
Rewards Points: 512
if the bosch bits dont work get yourself the hilti rotary hammer drill bits and just put it in the chuck of your regular hammer drill.
princelake is offline   Reply With Quote
Old 11-24-2012, 04:12 PM   #6
Too Short? Cut it Again!
Sounds like you need something like the bits mentioned. Your real tool supplier will have carbide and diamond tipped masonry bits. Might be worth it since 3/16" is a size you will use a lot I suspect.
Are you able to get into the surface at all. If so, are you sure you are not hitting steel rebar, plate or something as you go? A masonry bit will not help much with that!
Old 11-24-2012, 05:16 PM   #7
Household Handyman
Rewards Points: 1,408
"using bits from Home Depot". Home Depot sells a number of brands of so-called "masonry bits". A good, known brand, such as the Bosch mentioned may be the answer to your problem. Now--is the DeWalt 1/2" drill a "hammer drill"? I'm not familiar with the Mastercraft, so I can't judge it. You will need (can we say "must have") a good hammerdrill to do this job. I have drilled into a lot of old concrete and I don't know whether it was because of it's age or mix back then, but they are harder than today's concrete. 1) A good, brand name, carbide tipped masonry bit, and 2) a good, preferably brand name, hammer drill should drill into this concrete. Granted that a stone or re-bar will make the job harder. Someone with experience can tell if they are hitting a stone or a metal re-bar, but both can be drilled through with the proper tools and procedure.
Old 11-24-2012, 07:34 PM   #8
Rewards Points: 362
bits
Great advice from all. The tool I mentioned "Mastercraft" is from a company called Canadian Tire. I din't think they have entered the U.S. market but I'm sure you have similar companies. They aren't bad, but I consider their tools to be mostly throw away after use. I may have to invest in a good hammer drill ... Bosch, Dewalt, etc. but as my use for a hammer drill is limited, it's one of those investments to think about.
Old 11-24-2012, 11:02 PM   #9
journeyman carpenter
woodworkbykirk's Avatar
hte mastercraft tools hes talking about are known as kobalt in the u.s
come from the same manufacturere im pretty sure just get a differnt brand tag
woodworkbykirk is offline   Reply With Quote
Old 11-25-2012, 08:24 AM   #10
Rewards Points: 4,448
NEVER use a rotary-hammer / hammer-drill w/diamond bits UNLESS you have deep pockets - you'll destroy them in a heartbeat,,, we routinely use apron / vest store 3/8" carbide bits w/sds chuck for epoxy crack injection - never any troubles - they're cheap & we can always find an apron / vest store for more
Old 11-25-2012, 10:28 AM   #11
Concrete & Masonry
Rewards Points: 470
Heck, I've never even heard of a "diamond masonry bit", other than core bits that would fit in a huge core rig. I highly doubt you're going to find a diamond core bit at 3/16" though...........
As others said above, buy a decent carbide tipped SDS bit, and carefully chuck it into you're drill. It may take a few times tweeking the orientation in the chuck to keep it from wobbling.
jomama45 is offline   Reply With Quote
The Following User Says Thank You to jomama45 For This Useful Post:
princelake (11-25-2012)
Old 11-25-2012, 11:42 AM   #12
I have one 1/4"d. It is a core bit but fits a standard drill chuck.
The Following User Says Thank You to user1007 For This Useful Post:
oh'mike (11-25-2012)
Old 11-25-2012, 12:02 PM   #13
Concrete & Masonry
Rewards Points: 470
I'd LOVE to see a picture of a 1/4" diameter diamond core bit...............
Old 11-25-2012, 12:18 PM   #14
They are sold as masonry, concrete and tile bits. I have used mine mainly for drilling into masonry and concrete to fit anchors for hanging art. Has always worked flawlessly. I see there is a 3/16" bit for about $15.
http://dewalt.com/tool-parts/drillin...tile-bits.aspx
Old 11-25-2012, 01:04 PM   #15
DIY staff
Look on E-bay I use a lot of 1/4" hollow diamond bits-----I get them from Hong Kong for about $15.00 a dozen.
Use them for drilling porcelain tile.
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 07:25 PM
taking out existing insulation, concrete bolt question s002wjh Insulation 1 01-25-2012 05:37 PM
Why can't I find straight concrete drill bits? DawsonMobley Tools 13 12-13-2010 01:31 PM
Quick Question on concrete board membrane zpmontog0947 Carpentry 5 09-22-2009 08:01 PM
Concrete question Daniel O'Connor General DIY Discussions 1 11-22-2004 03:54 PM
