Concrete Basement Stairs - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-26-2008, 04:15 PM   #1
I have recently begun finishing the basement of my home. Currently I am in the middle of framing in two rooms and a bath but have recently decided that the exterior stairs must be addressed. The stairs are poured concrete, and although they are in relatively good condition for the age of the home, the rise and run of the steps are concerning (rise too high and run too short). As I am attempting to keep the cost of finishing the basement low I am doing all work myself and can not entertain options that require high costs or expertise.
thomasd333 is offline   Reply With Quote
Old 12-26-2008, 04:43 PM   #2
Registered User
Termite's Avatar
You're certainly not obligated to change those stairs by code unless there are some very strange circumstances. If you want to bring the rise and run into more "modern" dimensions, you're usually facing removal of the old stairs to facilitate reinstallation. If room allows, I have seen people frame stairs conventionally, resting the stair stringers on the old concrete stairs.
Can you post a picture of what you've got and give some dimensions? We might be able to get creative.
Old 12-26-2008, 04:49 PM   #3
I will try to post some pics and dimensions this afternoon. Thanks
Basement Stairs/ EZ Stairs mjkpainting Carpentry 8 02-24-2010 09:24 PM
Framing in basement attached to concrete blocks, how to insulate? drnormie Remodeling 11 01-21-2009 05:40 PM
Concrete walkup stairs from the basement handy man88 Building & Construction 3 09-08-2008 05:05 PM
Concrete stairs jmat1980 Building & Construction 2 04-18-2008 11:45 PM
Need help replacing some concrete in my basement. zmurphy Building & Construction 8 01-17-2008 08:10 AM
