Concrete Basement Stairs - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-17-2011, 12:46 PM   #1
Do I need a permit in New york to add basement stairs to the front and back, if I have a basement already? I live in a brownstone
excaliburleo723 is offline   Reply With Quote
Old 06-17-2011, 01:35 PM   #2
concretemasonry's Avatar
Rewards Points: 2,594
A permit is a local requirement, so visit or call to find out if one is required where you are. There may also be specific requirements depending on the location and type of building and improvements.
You did not say, but if it on the exterior, that complicates things since the neighbors may be allowed a say.
Dick
concretemasonry is offline   Reply With Quote
Old 06-17-2011, 02:49 PM   #3
Too Short? Cut it Again!
And find out if you are going to need an inspection to go with the permit. See if the inspector will approve your forming etc. so you don't pour the stairs only to have them rejected with threat of having to remove them.
At a crossroads in my basement project - waterproofing help needed callisto9 Building & Construction 37 07-06-2015 07:40 AM
Laminated flooring over basement concrete Woodcutter Flooring 2 10-25-2011 08:55 AM
doug fir post for stairs on basement concrete chulett Carpentry 22 02-17-2011 07:56 PM
Concrete Basement Beam jrepp44 Building & Construction 1 01-06-2010 01:39 PM
Concrete stairs jmat1980 Building & Construction 2 04-18-2008 11:45 PM
