Concrete Basement Beam - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-06-2010, 02:10 PM   #1
Rewards Points: 121
Given the following situation: 15' clear span between 12" x 18" concrete filled support columns 9' tall. The basement beam will be supporting 15' open web floor joist 16" on center on each side of the beam. Single story convential home above the basement which is 30' x 60'. Can a solid concrete beam with rebar be constructed to span this distance? If so what would the deminsions of the beam be? Would LVL or Steel be a better option for this basement beam? The reason I am considering concrete is that I have a pallet of extra concrete blocks left over from the basement construction and I could use these as the shell for the beam.
jrepp44 is offline   Reply With Quote
Old 01-06-2010, 02:39 PM   #2
Concrete & Masonry
Rewards Points: 526
Yes, but you'd be crazy to attempt it without engineering.
Much bigger than you would assume for that span.
Most likely.
I had a few concrete beams spec'ed by an engineer for our shop a few years ago (all block walls) and opted for steel beams as they were cheaper & much easier to install. Note that I do concrete work for a living, & the only way I could justify the concrete beams was to be able to say that "I did it".
jomama45 is online now   Reply With Quote
At a crossroads in my basement project - waterproofing help needed callisto9 Building & Construction 37 07-06-2015 08:40 AM
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 09:51 PM
Basement floor over concrete slab Straightgrain Flooring 9 03-09-2009 01:38 PM
ceramic over basement concrete ponch37300 Flooring 5 11-14-2008 01:42 PM
Temporary support for replacement of basement beam Mikedks Remodeling 8 09-14-2006 07:36 PM
