Concrete Backerboard Vs. Greenboard - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-21-2007, 11:58 PM   #1
Rewards Points: 1,062
Question
Concrete backerboard vs. Greenboard
it is not completely clear to me whether concrete backerboard is used IN PLACE OF or IN ADDITION TO greenboard drywall, when putting tiles ?
thx,
Old 05-22-2007, 05:54 AM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
thx,
Hi,
ALWAYS, ALWAYS, ALWAYS Use ONLY cementitious backer board when installing tile in a wet environment.
Pretty much Moisture Resistant (AKA 'green board') is now obsolete. It was used for decades as a 'bathroom' sheetrock.
Essentially, what it is: regular sheetrock with a wax coated paper over the surface as opposed to regular sheetrock paper on it's surface.
(The newer materials to use are Densarmor and XP board (Purple face) for environments that may have ''high humidity'')
Wet environments like a shower or whirlpool tub enclosure base - Always use cement board under the tile.
Here are some links on cement boards:
http://www.usg.com/navigate.do?resou...ment_Board.htm
http://www.usg.com/USG_Marketing_Con...tion_Guide.pdf
- Build Well -
Sleeve options for plumbing through concrete? Bruce L Plumbing 6 06-14-2008 09:38 AM
Extending Concrete Patio Slab bobo Building & Construction 6 04-17-2008 12:17 PM
stone veneer formula tom1st Landscaping & Lawn Care 1 07-08-2006 04:48 PM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 10:27 PM
